September 17, 2026, 03:05:53 pm
Hoffman Amps Forum image Author Topic: 6BL8/6CQ8 Interchangeable  (Read 5576 times)
« on: August 09, 2016, 04:49:34 pm »
Hi guys, I have an amp that would normally have a 6BL8 in the PI position, but found a 6CQ8 instead.
http://www.nj7p.org/Tubes/PDFs/Frank/093-GE/6CQ8.pdf
http://www.nj7p.org/Tubes/PDFs/Frank/127/6BL8.pdf
They have the same pin numbers but one is a pentode and the other is a tetrode.
Similar but different???? :dontknow:
Offline drgonzonm
Re: 6BL8/6CQ8 Interchangeable
« Reply #1 on: August 09, 2016, 05:17:23 pm »
post a schematic of the amp.  It would be nice to know how the tetraode/pentode is being used.
The posted amplification factors of the triodes are different.  How severe, not sure, remember, a lot of 12a_7 are used interchangeably.
« Last Edit: August 09, 2016, 05:24:43 pm by drgonzonm »
« Reply #2 on: August 09, 2016, 06:32:14 pm »
Exactly.
To the eye, that "tetrode" does not look like tetrode curves. No kink.
However the pentode will pull-down a bit more than the "tetrode".
Whether it makes a difference will depend a LOT on what the circuit asks of it.
If this a Dyna-like pentode voltage amp and triode cathodyne, it may make no real difference at all. Many Dynas are re-rigged each time the original recipe tri/pent becomes scarce.
When in doubt, put in the type the factory calls for. TubeDepot has it for $7.
« Reply #3 on: August 09, 2016, 06:33:19 pm »
Schematic
