September 13, 2026, 02:14:48 pm
Hoffman Amps Forum image Author Topic: Diode spacing??  (Read 4917 times)
Offline Ambugaton
Diode spacing??
« on: August 12, 2016, 10:12:37 pm »
Are there any general rules for diode spacing for a SS rectifier? My space is a little tight and the leads for some of the diodes will be about 9/32" apart. Is that safe?
Re: Diode spacing??
« Reply #1 on: August 12, 2016, 10:15:51 pm »
> about 9/32" apart
1/4"? Seems generous to me.
Re: Diode spacing??
« Reply #2 on: August 12, 2016, 10:22:20 pm »
9/32" is fine for 1N4007 or other DO-41 case style diodes.
Offline Ambugaton
Re: Diode spacing??
« Reply #3 on: August 12, 2016, 11:25:28 pm »
Thanks. I'm completely ignorant to all of this and didn't know if there was a risk of arcing if they were too close.
Re: Diode spacing??
« Reply #4 on: August 13, 2016, 02:22:32 am »
The arching risk depends on the voltage
if you use 1000v or higher B+ then you must pay particoular attention as to avoid risks
a bit less if B+ is in orther of 800v and so on
May be here you can read something of interesting also if dedicated to PCB traces and SS components
http://www.smps.us/pcbtracespacing.html
http://pcbdesign.smps.us/creepage.html
http://www.infineon.com/dgdl/Infineon+-+Application+Note+-+PowerMOSFETs+-+CoolMOS™+-+Electrical+Safety+and+Isolation+in+high+voltage+Applications.pdf?fileId=db3a30433d1d0bbe013d20e0cbf017fe
