September 14, 2026, 07:28:54 am
Hoffman Amps Forum image Author Topic: Marshall Blusebreaker TREMOLO  (Read 4381 times)
« on: September 10, 2016, 06:24:57 am »
Hi guys,Interested in camsna Ceriatone build and eager to here the TREM, although I'm not a big fan of the trem. :dontknow:
Form all the vids of the original amp it seem that the trem works and sounds fine.
I see that Ceriatone has gone down a different path in a bias trem. Is this just a safe bet or a copyright thing, although Metro amps have done a close version of the original trem.
Has anyone played an original BB an confirm that if works and sounds fine.
I'm thinking of a clone using the Ceriatone layout but I need to settle on a trem.
It seems that the J174 FET is a tad hard to find, any ideas on a substitute. Thanks
Re: Marshall Blusebreaker TREMOLO
« Reply #1 on: September 10, 2016, 07:32:51 am »
The circuit is a Fender 6G16 circuit with a couple parts values changed. It also uses a red LED rather than a cap/resistor on the cathode of the oscillator. The LED produces a much bigger tremolo signal, although since it's modulating EL84s, the LED is not really necessary. The 6G15 is a very smooth, effective tremolo circuit. Hoffman uses this circuit in his AB763 amps.
Most any general purpose N-channel JFET will work. It's just being used as a voltage controlled resistor. I've never heard this circuit before so I have no idea how effective it is.
Offline bnwitt
  • Crankin' out the tone.
« Reply #2 on: September 10, 2016, 09:50:17 am »
actually it's EL34s or KT66s
« Reply #3 on: September 10, 2016, 10:58:18 am »
Yep. Had a brain freeze.
