September 08, 2026, 08:43:15 am
Hoffman Amps Forum image Author Topic: 4 knob tone stack  (Read 30799 times)
4 knob tone stack
« on: October 11, 2016, 07:49:00 am »
On the D-inspired amps I've done, the "mids" are critically important in the tone and definitely influence the overdrive tone in the amps.
I've been wondering how to shape the mids more and came up with this idea.  IF you look at the Duncan Tone Stack Calculator and use the "Vox" program to approximate the values closer to this tone stack,  you will see that a .01 mid cap greatly increases the low mids and the .05 (or .047) cap has less low mids.
http://www.duncanamps.com/tsc/
The idea is to use the mid shape pot to dial in the type of mid tones that you want.  I realize there are other ways to approach this also.
I am thinking this could be very useful on some builds where the mids are so critical in the OD tone.
Thoughts?    And does anyone have a 4 knob tone stack schematic that is used with a tube (not solid state) amp ?
I just thought of this idea this morning so I have not tried it yet.
Re: 4 knob tone stack
« Reply #1 on: October 11, 2016, 09:29:40 am »
Ciao Jeff
This Tone Control (from Weber AB200 Kit) didn't has 4 pot but has 4 knobs and the rotary switch seems there with the purpose to tailor the mids
Here (Ampmaker Kit) the approach is different, the knobs are only 3 but one is devoted to control the mids in a different gain stage
« Last Edit: October 11, 2016, 04:25:11 pm by kagliostro »
Offline SILVERGUN
« Reply #2 on: October 11, 2016, 09:35:08 am »
This is what I did on a friend's harp/guitar amp...
I wanted to give him the ability to tailor mids between a more standard scooped out stack for playing guitar, or a mid heavy tone for playing harp through the same amp.
Not 4 pots, just 3 pots and a rotary switch.
I "borrowed" the approach for the schematic from Sluckey's AC15
EDIT:
Looking back over this I now see that you appear to have been looking for different input...I took it as a chance to throw out ideas, when it looks like I missed the intent of your post.
YOUR idea does look like a smart way to have somewhat of a sweepable mid shape control!
« Last Edit: October 11, 2016, 11:53:16 am by SILVERGUN »
Offline mwelch55
« Reply #3 on: October 11, 2016, 03:09:23 pm »
What about the Engl 530 Tonestack?
Mike
« Reply #4 on: October 12, 2016, 02:30:08 am »
Hi Jeff
Make the 100k slope resistor variable.
« Reply #5 on: October 12, 2016, 03:14:14 am »
There is also the Merlin's version of the James with the shift control option, but it is a 3 knob Tone Control
With 4 knobs (one is a double pot) there is also the Blackstar (they call it ISF)
Patent and explanations (with graphics)
https://docs.google.com/file/d/0BwMWxzd7lEJ4WWZselRsb3R5Q0U/edit?pli=1
Demo
https://youtu.be/C7Xig5d3Mao
but I don't know if this can be of your interest also because it is in a SS circuit and to use it in a tube amp requires some experiment
suggested values to be tried for tube amps are:
C1 = 470nF, C2 = 220nF, C3 = 220nF and C4 = 4.7nF, R4 = 1k -- pot near for sure is a dual 10k linear pot
« Last Edit: October 12, 2016, 03:20:01 am by kagliostro »
Offline SILVERGUN
« Reply #6 on: October 12, 2016, 09:39:09 am »
Based on your idea, I adapted my drawing to reflect a possible application for the standard TMB stack.
I will be trying this in the near future and report back with findings. Not too tough to hook up.
« Reply #7 on: October 12, 2016, 10:54:28 am »
Ciao SILVERGUN
a possible alternative ?
Offline SILVERGUN
« Reply #8 on: October 12, 2016, 11:14:00 am »
Thanks Franco,
Yes, I can try it that way as well.
I imagine pot values will be critical to getting the blend correct.
« Reply #9 on: October 12, 2016, 11:23:04 am »
For "my" version try 1M
I borrowed it
the pot connected that way is a way to avoid the use of a rotary switch with capacitors when you have it following a pentode preamp stage
This is what propose Tubeswell
« Reply #10 on: October 12, 2016, 12:15:11 pm »
Hi Jeff
I have used this idea a lot, but I cannot come up with a name for it.  I did label it as a mid shift on one amp, but not exactly the same.  I also make the Bass cap switchable between Stock Fender and Marshall.  Clean to mean, but I will say I have never tried it with an overdrive.
« Reply #11 on: October 13, 2016, 05:28:41 am »
Yeah, that's what I'm talking about
« Reply #12 on: October 19, 2016, 09:00:53 am »
I've find also this schematic (of a modded Alembic F2B)
it is one other option to have a 4 knob TS with two knobs devoted to the mids
