September 13, 2026, 09:07:46 pm
Hoffman Amps Forum image Author Topic: 6v6 push pull circuit change  (Read 15609 times)
Offline fossilshark
  • No life til' leather
« on: October 23, 2016, 01:51:15 am »
In a push pull 6v6 power amp, using this circuit as an example, could i wire everything exactly the same except disconnect the screen taps or connect them somewhere else in the circuit if my transformer doesnt have the necessary 40% windings? How would this affect the circuit
~SNOWBLIND~
Re: 6v6 push pull circuit change
« Reply #1 on: October 23, 2016, 02:55:02 am »
Offline fossilshark
« Reply #2 on: October 23, 2016, 09:16:55 am »
Like that except would i have to change the 12ax7 wiring too? It looks like the fender schematic has one tube amplifying the positive of the signal and the other is doing the negative. In the schematic i posted the 12ax7 is wired different i think. Im a little new to this sorry for the dumb questions  :laugh:
~SNOWBLIND~
« Reply #3 on: October 23, 2016, 10:12:58 am »
I think Timbo was showing an example of how to do a screen tap without UL connections, NOT how to re-do your PI
« Reply #4 on: October 23, 2016, 10:58:27 am »
Which is your purpose ?
There are thousands of schematics that didn't use UL OT
Why your choice was that schematic that you can't build because of the missing UL connections ?
If you say more about your need, someone can give you councils about possibilities
Offline fossilshark
« Reply #5 on: October 23, 2016, 11:36:43 am »
Yes sorry. Im finishing up a build and i have everything on this schematic built in my power amp section, until i went to wire up the OT and realized that it did not (or at least was not specified by the ebay seller) have the windings for the screen taps, just the 8k center tapped primary. For $15 im not terribly worried if i have to but a new one, although to buy them new is very expensive for me. So could i just disconnect the screen taps? Or i should be asking, what is the purpose of the screen tap connections?
~SNOWBLIND~
« Reply #6 on: October 23, 2016, 12:30:16 pm »
No. The screens must be connected to a B+ supply, similar to what Timbo showed.
Offline fossilshark
« Reply #7 on: October 23, 2016, 12:43:01 pm »
So if i connect them to b+ instead of the transformer i should have no problem?
~SNOWBLIND~
« Reply #8 on: October 23, 2016, 01:25:31 pm »
Offline fossilshark
« Reply #9 on: October 23, 2016, 01:46:42 pm »
Thats great, thanks!
~SNOWBLIND~
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #10 on: October 23, 2016, 04:49:53 pm »
What does your power supply look like?
That presence control isn't going to do much unless you hook up some negative feedback from the speaker output.
Offline jbrew73
« Reply #12 on: October 24, 2016, 02:24:51 am »
What the others said already. Most guitar amps don't use ultra linear OTs. You only 'need' to hook up ultra linearly if you want to run in ultra linear mode. (UL is designed to make the screen voltage vary in synch with the plate voltage. This sacrifices a bit of gain in return for giving a more 'hi-fi' quality output signal. But it isn't necessary, or even strictly desirable, to run a guitar amp this way.)
