August 03, 2026, 10:52:10 pm
Hoffman Amps Forum image Author Topic: Best replacement for a 70uf filter cap Twin Reverb AC568  (Read 4215 times)
Offline Planobilly
« on: December 19, 2016, 10:52:39 am »
Hi guys,
The 70uf cap is not made any longer as far as I can tell. JJ makes a 80uf and so does F&T.
Any suggestions?
Also has anyone converted  the AC568 back to a Blackface?
Thanks,
Billy
Between fishing, flying, and fooling around with guitar amps, somehow 70 years got behind me. Shorter of breath and one day closer to death as the song goes.
Re: Best replacement for a 70uf filter cap Twin Reverb AC568
« Reply #1 on: December 19, 2016, 11:37:24 am »
Hoffman sells a couple brands of 100µF/350V caps that are ideal for that.
« Reply #2 on: December 19, 2016, 03:39:45 pm »
With SS rectifier of the Twin, Sluckey's suggestion will work just fine.  Yes, I have "Blackfaced" this circuit.  Really, CBS had not changed a whole lot.  If I am not mistaken, you will still have the 85 watt so when done it should be just like a pre 1968.
A lot of these had the EV speakers installed and will hold a clean quite well.
Offline Planobilly
« Reply #3 on: December 19, 2016, 07:39:53 pm »
Thanks Guys,
It looks like I am the first person to work on this amp. Everything is original. There is very little in this amp that changed from the AB763. I had a couple of 80 uf caps in stock so I only need the 20 uf ones. I have some 100 uf also.
