September 15, 2026, 09:55:05 pm
Hoffman Amps Forum image Author Topic: Fender Amp Convenience outlet and 67 Princeton Reverb  (Read 4867 times)
Offline guitardude57
« on: January 20, 2017, 03:35:06 pm »
Howdy all.
I am looking for a supplier, to get a Fender style convenience outlet.
I got one from somewhere... when I did my Bassman 70 into a Dumble build.
Do not know where I got it.
Looking for a 3 pin grounded one.
Redoing a 67 Princeton Reverb, and the owner wants a 3 wire power cord,
and the outlet to match.
This amp is incredibly clean, other than a couple bad caps in the can, and the bias cap shorted,
and the speaker hosed... not any rust or discoloration to the chassis.
The can cap is a Sprague, and the orange and blue banner label is perfect.
I may just rebuild it, and stick it back on there...
Likely will stick a Jensen C10N speaker in it, as those sound better than the Oxford jobby
that was also found in these amps.  And in this one... burned VC.
Not even a spiderweb in there... never seen one this clean.
I would place this one in the $2600 on up value...
I mentioned for him to keep the original power cord, for when he sells it.
I will disconnect the ground switch and death cap, and bypass them.
No need to remove them.
Thanks!
"I am never surprised, and always amazed".
Mike
Re: Fender Amp Convenience outlet and 67 Princeton Reverb
« Reply #2 on: January 20, 2017, 04:31:26 pm »
Hell yes!
Thank you Brother!
Mike
Offline p2pAmps
    • p2pAmps
« Reply #3 on: January 20, 2017, 08:50:45 pm »
Those are hard to come by, buy them all.  I found a lot of 40 so I grabbed em.
Everything Affects Everything
