August 05, 2026, 05:50:51 am
Hoffman Amps Forum image Author Topic: JCM 2204 Ceriatone build  (Read 8691 times)
Offline Oddvar
« on: January 22, 2017, 08:30:19 am »
HI.  I was wondering if anyone could hint on where to look when a JCM 800 build doesn't make any sound, exept a very low hum in the speaker when turned on.  I have gone through most of the amp many times, but doesn't seem to find the problem.  Voltage seems to be ok the places B+ etc.
The only thing I am a bit uncertain of is the voltage coming from the transformer to the board by the rectifiere, only about 25 millivolts there...
No reaction on any pot, no sounds what so ever touching inside the amp...
I have changed all tubes as well...
« Last Edit: January 22, 2017, 08:33:02 am by Oddvar »
Re: JCM 2204 Ceriatone build
« Reply #1 on: January 22, 2017, 08:50:36 am »
Offline hesamadman
« Reply #2 on: January 22, 2017, 08:51:32 am »
Does this layout implement both high and low input jacks?
Offline Oddvar
« Reply #3 on: January 22, 2017, 08:56:38 am »
Yes it does...(Non works)
« Reply #4 on: January 22, 2017, 09:12:33 am »
Maybe your meter is set to measure DC volts? Change it to measure AC volts and you'll probably have about 325VAC.
Offline hesamadman
« Reply #5 on: January 22, 2017, 09:20:28 am »
If you're getting proper B+, the PT secondary has to read more than mv.
Ok. Well first thing. It's not in the first gain stage. However....it could be your input jack wiring. If wired incorrectly, you could be grounding out the signal. Those should be switched jacks and are meant to ground certain portions when not in use.
Part of my trouble shooting method that I use is, Go to phase inverter input, disconnect it, use alligater clips to an input jack, make sure your power amp is working. Then you can narrow it down to be if it's in preamp or power amp.
Offline Oddvar
« Reply #6 on: January 22, 2017, 09:37:02 am »
Meter was set to DC, you are right, again.  Measure 707 v.
Offline Oddvar
« Reply #7 on: January 22, 2017, 09:47:02 am »
This is how it looks like at the moment.  I am a bit uncertain if the jacks are done right.
« Reply #8 on: January 22, 2017, 10:28:00 am »
The input jacks on the 2204 can be tricky to wire correctly due to the clever way the jack switches work. Study this schematic and insure your jacks are wired accordingly.
     http://el34world.com/charts/Schematics/files/marshall/Marshall_JCM800_2204_Lead_Series.pdf
Offline hesamadman
« Reply #9 on: January 22, 2017, 10:52:05 am »
A quick test would be to de solder the paralleled 470k/500p cap from the input jack to the gain pot. Just disconnect it from the jack not the pot. Use alligator clips on the end of your guitar cable. Plug into your guitar. Clip a wire onto the end of instrument cable to chassis. Clip a wire on the tip of the cable to the 470k/500p cap. This bypasses the first gain stage and the input jacks.
Offline Oddvar
« Reply #10 on: January 22, 2017, 11:17:12 am »
No reaction at all when I tried that now...
Offline silverfox
« Reply #11 on: January 22, 2017, 12:53:06 pm »
Amp only has low hum
That is a subjective statement. I built an amp that has a low hum as soon as I turn the power switch on. No warm up time for the tubes. That is because the 60 cycle hum is being directly coupled to the output transformer at a low level.
Try this: Plug just a guitar cable into the return jack of the send unit and see if you get any buzz through the power amp. If you still don't get any sound out check your power supply voltages. I can't tell if the power supply capacitors are wired correctly or not from the picture. How experienced are you working with high voltages. There is enough present on the power supply to Kaknock you over if you contact it with your body.
If you are still not able to find the problem, start checking the power supply voltages and post them here starting with the power supply.
silverfox.
Offline Oddvar
« Reply #12 on: January 22, 2017, 01:39:18 pm »
Thanks Silverfox, but no sound in the sendsection.  This is my tenth tube build, but I'm not a voltage man, more like a musician trying to understand what seperates good sound from better ones. This build seems a bit different than the others, it's making no sound what so ever, whatever I do.  The hum, when turned on is low, I can hear it when I put my ear to the speaker.  That's it. and I have gone over it many times.
« Reply #13 on: January 22, 2017, 02:54:59 pm »
I'm a voltage guy NOT a musician, but I had to learn to make cool sounds from the guitar to "prove" my voltages, time to learn meters 101 :laugh:
Offline hesamadman
« Reply #14 on: January 22, 2017, 03:27:33 pm »
Again, from here, all you have to do is narrow it down. We determined it's not in the jacks. Just de solder certain parts, clip in your guitar cable and see what happens. Disconnect the middle lug of the MV. This is your PI input. Clip your guitar cable there. Any sound? If no, look over your power amp components.
Offline silverfox
« Reply #15 on: January 22, 2017, 03:32:06 pm »
Just to be sure, you want to plug the cable into the Return Jack. If that is what you did and got no sound, then in many respects the simplest half of the amp is not working. Not to say that is the source of the problem but if that's not functioning the problem is likely global. You are going to have to measure voltages at least, to simplify the troubleshooting process.
One of the greatest hazards in measuring voltage is, inadvertently touching the meter probe to a nearby terminal and causing a short-spark that scares the crap out of you. Here's an idea. Turn the amp off and unplug it. Now practice measuring the voltage at various points. Be sure to develop good practices such as: Don't lean with one hand on something while taking the measurement. Always keep one hand at your side, behind your back at best so as not to complete the circuit through your body should you contact high voltage.
After you've practiced a while, your ready to take measurements under power.
Does the power on indicator light? I would have suggested using a dim bulb tester but at this point it's moot. If this uses a rectifier tube, make sure that is the tube in the rectifier socket. Don't know what would have happened if it wasn't but thought I'd suggest it.
Welcome to troubleshooting.... Someone else is typing while I'm getting ready to post. Perhaps duplicate info.
silverfox.
Offline hesamadman
« Reply #16 on: January 22, 2017, 03:37:04 pm »
Sorry. If you have fx loop, disregard my last comment. I'm not familiar with Ceriatones 2204. Mine does not have fx loop.
Offline MFowler
« Reply #17 on: January 23, 2017, 09:49:11 am »
Here is the voltage chart for the Ceriatone 2204 120v version
