September 08, 2026, 11:35:07 am
Hoffman Amps Forum image Author Topic: 100 watt Fender..Too MUch Compression??  (Read 4933 times)
Offline TerryD
« on: March 12, 2017, 06:29:09 pm »
You guys helped me turn my 100 Fender PA into several amps.  1stock, 1Blackface twin and 1 chain with the remaining two amps.
The amp has a master volume and reverb.
I don't know it kind of sounds boxy, like compressed not open.  Is there anything I can do to change that?
Thanks ahead,
Terry
Re: 100 watt Fender..Too MUch Compression??
« Reply #1 on: March 12, 2017, 07:16:07 pm »
there is, but a schematic might help, you need to "see" your signal path to see where things get wonky.
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« Reply #2 on: March 12, 2017, 07:53:33 pm »
did you try another speaker cab ?
P.S.: call me Alvin.
Offline TerryD
« Reply #3 on: March 12, 2017, 08:07:04 pm »
I don't have something I can put up.  It's a Fender 100 watt PA head.  Open back cab with 2 jensens, 1 ceramic, 1 alnico.
Offline BetterOffShred
  • I play tube amps..
« Reply #4 on: March 19, 2017, 04:27:09 pm »
What kind of NFB circuit did you implement as well?  I hear a big difference with NFB circuits personally, and just changing a single value there usually "open" things up IMO! Also as Colas pointed out, I'd run it out to something known to sound beefcake, like a buddies 1960B or something  :icon_biggrin:  At least you will know if the Amp itself is culprit or if it's just the box.
-Brett
