September 15, 2026, 04:20:29 am
Hoffman Amps Forum image Author Topic: Question on Hoffman Deluxe Reverb build  (Read 5074 times)
Offline Joeriz
« on: April 09, 2017, 06:28:40 pm »
Hello,
I am currently building a Hoffman Deluxe Reverb. In the instructions I received with the board from the Airtight Garage it says that one should either ground the green/yellow 6.3v center tap coming from the power transformer or use the 100 ohm resistors on the board...but not both. My question is: is there an advantage to one approach vs. the other?
Joe
Re: Question on Hoffman Deluxe Reverb build
« Reply #1 on: April 09, 2017, 07:24:03 pm »
Flip a coin.
Offline Joeriz
« Reply #2 on: April 09, 2017, 09:13:51 pm »
I can do that.
Thanks!
Offline Joel
« Reply #3 on: April 09, 2017, 09:51:38 pm »
As I undertand it, the 100 ohm resistors simulate a centre tap.  Useful when the 6.3Vac winding is not of the centre tap variety.
The mouth of a happy man is filled with beer  - Egyptian Proverb
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #4 on: April 10, 2017, 04:32:20 pm »
Yeah as stated, the 100 ohms simulate a center tap, so you're wasting a few cents using them if you have a center tap.  On the other hand, if you want to go for almost 0 heater noise (so long as other things are done right) you can use a hum balance pot,  The center tapped transformer should be pretty perfectly balanced, BUT that doesn't mean it 100% is.  The hum balance pot allows dialing the hum to near 0.
~Phil
Phil Davis
tUber Nerd =|D
Offline Tone Junkie
« Reply #5 on: April 10, 2017, 07:11:41 pm »
+1 for humdinger.
Bill
