September 15, 2026, 05:04:14 pm
Hoffman Amps Forum image Author Topic: Tremolo intensity too deep or intense  (Read 5374 times)
Offline dude
« on: April 25, 2017, 01:15:54 pm »
The tremolo on the J20 Ampeg modelled after the 6G3, has way too much intensity. I usually have the pot set at 1 just enough to get tremolo.
I looked at the 6G3 pretty much the same as this J20, schematic attached. speed works great, just way too deep.
I searched this topic here and elsewhere but found nothing.
I was thinking if I raised R27, to 470K this might cut some intensity but looks like a voltage divider with the (2) 220K's..?
al
Re: Tremolo intensity too deep or intense
« Reply #1 on: April 25, 2017, 01:47:17 pm »
And leave the 220K adding the 470K resistor between R27 and C20
connecting the other side ot the added 470K resistor to ground ?
This way your oscillator signal will be around 30% lower to the intensity pot
« Last Edit: April 25, 2017, 01:49:19 pm by kagliostro »
« Reply #2 on: April 25, 2017, 01:50:35 pm »
You're on the right track but you may have to increase R27 to 1M or even higher. Also put a .1µF cap from the right end of C 20 to ground.
I believe you are the first dude to complain this bias vary trem is too strong.  :icon_biggrin:
Offline dude
« Reply #3 on: April 25, 2017, 02:15:04 pm »
Must be those used old stock tubes I'm using.... but it is very deep... :icon_biggrin:  BTW, your plexi drawing of Mark Huss's is just like the November, I copied. Works great but I lost a leg on the switch, I have to get that iron off sooner, tight spots and poor eye site,  :laugh:
When I get a new switch, hopefully that pop will be gone.
I'll try the 1meg, then K's suggestion. (that added 1uf  e-cap's a filter..?)
thanks,
a
« Last Edit: April 25, 2017, 02:18:31 pm by dude »
« Reply #4 on: April 25, 2017, 03:02:33 pm »
It's not a 1µF. It's .1µF. Maybe even just use a .047µF. You can look at it as a smoothing filter cap or you can look at it as part of a capacitive voltage divider, the other part being the existing .1µF cap. Just another way to knock the tremolo signal down some more. You may not need the bigger resistor and the cap, but a lot of circuits have both.
« Reply #5 on: April 25, 2017, 03:46:31 pm »
.... you can look at it as part of a capacitive voltage divider .....
I like to think so
