September 14, 2026, 05:57:38 am
Hoffman Amps Forum image Author Topic: Sound with MV at zero  (Read 7537 times)
Offline jokn
« on: May 09, 2017, 11:47:54 am »
Hi everybody, first post here (aside from introduction). I'm finishing my project, which is a preamp of my own concoction (firmly based on existing high-gain designs) and an AX84 PP50 power amp/power supply with some changes. I'm a little perplexed (I'm easily perplexed by this stuff , being a neophyte :icon_biggrin:) because on channel 2 I'm getting sound out of the speaker even with the gain about half-way up and channel volume at zero. This only occurs on channel 2, not on channel 1. I also tried grounding the  wiper of the CH 2 volume pot, same result. How is the signal getting to the PI and onward?
Re: Sound with MV at zero
« Reply #1 on: May 09, 2017, 11:50:31 am »
Need to see schematics of your preamp and power amp.
Offline jokn
« Reply #2 on: May 09, 2017, 01:09:07 pm »
D'oh! I thought I'd managed to attach those to the original post, but guess not. Let's try again.
« Reply #3 on: May 09, 2017, 06:02:56 pm »
FULL sound? Or a little tinny leak?
That is a HIGH gain side-path. Would not take much leakage to be audible. IF the pot is well grounded, I would expect mostly capacitive sneakage, which will be mostly highs.
Offline jokn
« Reply #4 on: May 09, 2017, 09:48:55 pm »
It's a very low volume leak, and there's definitely no low end whatsoever. It doesn't really bother me that much, I just wish to understand what the mechanism is.
« Reply #5 on: May 10, 2017, 03:00:37 pm »
May be also a defect on the pot, I've seen some (old) pot that didn't correctly go to zero ohms
Offline jokn
« Reply #6 on: May 11, 2017, 01:13:16 pm »
I measured the pot before installing it and it does go to zero. Also, shorting the signal to ground from the top of the pot should take the pot totally out of the picture, right?
Offline jokn
« Reply #7 on: May 26, 2017, 01:06:17 pm »
Progress: I unsoldered the wire from the NFB to the presence pot, and presto, no more sound audible with the volume on zero. Now my question is, is there anything I could do to keep the presence control and alleviate the problem? Would a shielded NFB wire from the speaker jack to the board be a good idea?
« Reply #8 on: May 26, 2017, 01:09:06 pm »
Swap the OT primary plate leads.
Offline jokn
« Reply #9 on: May 26, 2017, 01:33:29 pm »
When I originally finished the build and powered on, thre was a terrible howl. A bout of googling led to the solution of swapping the plate leads. I had already shortened the plate leads so I swapped the secondary leads instead. That fixed the howling problem, and now I'm afraid I'll have the same problem if I swap them back.
« Reply #10 on: May 26, 2017, 01:47:17 pm »
Give a try to this
disconnect Relay 2 and use at his place a pair of mix resistors (220K-330K-470K at your taste)
to connect the CH1 & CH2 MV pot wipers to the following circuit
What happen ?
Offline jokn
« Reply #11 on: May 26, 2017, 02:08:46 pm »
Ok, I'll give that a try as soon as I get a chance.
Offline Tony Bones
  • Thread Killer
« Reply #12 on: May 26, 2017, 02:48:50 pm »
Seems to me that signal from V3 is sneaking into your NFB wire. Check the location of associated leads. See if moving them helps.
Where is the NFB resistor (R49)? It should be closer to the junction of R48, R36, C18 and the presence pot than the OT. In other words, if you need to have a long wire going past other stuff, you want it on the OT side of R49, not the PI side. That side will be less susceptible to picking up other signals and noise.
Offline jokn
« Reply #13 on: May 27, 2017, 06:10:34 am »
Franco: I removed relay 2 from the circuit and connected the two channel volumes to V4 pin 2 via 220k resistors. No effect on the bleed-through, but a great improvement as it lowers part count and improves reliability. I knew there had to be a simpler way than having two relays, i just wasn't smart enough to find the answer. Mille grazie!
Tony: tried moving those leads around, but no joy. In the pictures you can see the NFB circuit. It is pretty much as you say it should be, with the long wire on the speaker jack side of R49, and everything else close together. Thanks for the suggestions, guys. I really appreciate you taking the time to help!
« Reply #14 on: May 27, 2017, 11:58:29 am »
Glad about what you say, but I was hoping in a different result
I was thinking that the AC signal was jumping from one contact of the relay to the other due to the capacitance between electrodes
but that isn't the case
OK, if the arrangement with mix resistor will be your final solution, remember you can adopt a larger mix resistor value for the channel
you like to tame to have a level similar to the other channel when you swap from one channel to the other
(220k + 330k or 220K + 470K as an example)
Offline jokn
« Reply #15 on: May 27, 2017, 12:32:46 pm »
that's a good point about the different resistors, Ch2 could use some padding relative to Ch1. In a further development, I connected the two volume pots (via the mixing R's) to C17, bypassing the FX loop- and that solves the bleed-through entirely. So now it's on to figure out what in the FX loop was causing the trouble.
« Reply #16 on: May 27, 2017, 02:47:02 pm »
Using an highlighter control the schematic with your layout, sometime happens to be wrong and not able to see where
http://el34world.com/Forum/index.php?topic=17701.0
Ciao
« Last Edit: May 27, 2017, 02:50:27 pm by kagliostro »
