October 06, 2026, 12:54:49 pm
Hoffman Amps Forum image Author Topic: Fender Twin Vibrato Problem  (Read 8459 times)
Offline ElPedro
« on: May 13, 2017, 09:33:22 am »
Hey all.  Having trouble with my Fender Twin.  The Vibrato takes a little bit to engage after I turn it on. Once it has come on, I can turn it on and off and it works fine.
When I first turn it on, I can hear the vibrato thumping, but the guitar signal isn't getting through to the vibrato.
I'll try swapping the tube, but are there any other suggestions?
Re: Fender Twin Vibrato Problem
« Reply #1 on: May 13, 2017, 12:53:08 pm »
Which model twin are you talking about? There's a big difference in the vibrato circuits of different models.
Offline ElPedro
« Reply #2 on: May 13, 2017, 02:20:38 pm »
Sorry...
It's an ab763. Not a reissue.
« Reply #3 on: May 13, 2017, 03:25:13 pm »
Replace the tube first. Then replace the roach (optocoupler).
« Reply #4 on: May 13, 2017, 09:37:29 pm »
Slow-to-start is more likely tube or cathode cap.
It *could* be that once it comes on, it holds a charge for a while so then it goes off/on quickly, but not if it has been dead a while.
Without looking, if this model has a kick-start (negative bias when off), that could have failed, but unlikely.
I would rate opto-coupler low on a list of slow-to-start reasons, but optos do have some strange failures.
Offline ElPedro
« Reply #5 on: May 13, 2017, 09:55:59 pm »
Thank you for your thoughts and ideas. I will try the tube and cap tomorrow. This is a kickstart model - I remember the pin on the back of the rca jack read somewhere around -55vdc when I checked it.
« Reply #6 on: May 13, 2017, 11:54:11 pm »
+1
if new tube doesn't do the trick, replace cathode cap with a 47uF 25V.
Offline ElPedro
« Reply #7 on: May 14, 2017, 05:57:47 am »
Would a 50u 50v work ok?
« Reply #8 on: May 14, 2017, 07:29:48 am »
yes
Offline ElPedro
« Reply #9 on: May 15, 2017, 07:07:57 am »
Thanks, all.  It was the roach.
« Reply #10 on: May 15, 2017, 11:03:32 pm »
So Sluckey was right.
