August 05, 2026, 05:49:27 am
Hoffman Amps Forum image Author Topic: This circuit for guitar amp  (Read 4508 times)
Offline fossilshark
  • No life til' leather
« on: May 15, 2017, 07:32:06 am »
Ive used this circuit as a headphone preamp, but would i be able to increase power output from the mosfet to get mabey 5 watts out of it? Or should i just replace the mosfet with a 5w audio amp chip?
~SNOWBLIND~
Re: This circuit for guitar amp
« Reply #1 on: May 15, 2017, 09:47:07 am »
Ciao Fossilshark
Your image results to be hard to read, seems that this is the same schem, only more readable
http://www.instructables.com/id/Class-A-Hybrid-Headphone-Amp/
« Last Edit: May 15, 2017, 11:11:44 am by kagliostro »
« Reply #2 on: May 15, 2017, 04:16:37 pm »
This.
Yes, a headphone amp "can be" a loudspeaker amp, except you want about 1,000 times more power. So simple-stuff which is also inefficient may be practical at phone level but excessive at loudspeaker level. This topology won't reach 25% efficient. That means to make your 5 Watts it must dissipate over 20 Watts. This is essentially the heatsinks from a 40 Watt push-pull AB transistor amp, 5 to 10 times the heatsinking you need for the 5W chip amp.
