September 15, 2026, 12:10:21 am
Hoffman Amps Forum image Author Topic: Lowering B+  (Read 4341 times)
Lowering B+
« on: June 16, 2017, 10:22:40 pm »
Hi guys, I have this now sorted. http://el34world.com/Forum/index.php?topic=22066.0
The PT has a HT of 360-0-360, so I was taking it as gospel, but in fact it's producing 380v each leg.
This inturn gives me 450v after the 5u4gb rect loaded. So all good
The one concern is when on standby the dual 32/32-500v cap sees 520v
Do adding zener diodes on the PT CT cause a problems to a rectifier valve
Re: Lowering B+
« Reply #1 on: June 17, 2017, 02:35:10 am »
Ciao TIMBO
If you have a bias tap (that you use) on that transformer, if you add zener on the CT, remember that bias components values must be revised in order to maintain the same negative voltage
About zener on CT and problems to the tube rectifier, I think that there aren't, but wait for the opinion of someone who is more skilled than I'm
The 380v are without load or with load ?
Re: Lowering B+
« Reply #2 on: June 17, 2017, 04:58:00 am »
Thanks K, 380v is loaded.
