September 14, 2026, 04:04:08 pm
Hoffman Amps Forum image Author Topic: Supro S6424 project  (Read 50081 times)
0 Members and 3 Guests are viewing this topic.
Supro S6424 project
« on: July 13, 2017, 12:29:31 pm »
I've finally started this project. All parts have been received and the build is under way. I'll eventually make a web page for this amp, but I have a lot of other stuff going on right now too. Meanwhile, here are a couple pics of completed chassis work to give you an idea what it's gonna look like...
EDIT... here's the layout document...  http://sluckeyamps.com/supro/supro.pdf
« Last Edit: July 13, 2017, 05:09:34 pm by sluckey »
Re: Supro S6424 project
« Reply #1 on: July 13, 2017, 01:07:55 pm »
Nice as always!  I'm looking forward to getting your take on the 1 knob tone n if you tweak it.  I need to get my project from a 2 knob to a 1 knober, so please don't patent it yet :laugh:
« Reply #2 on: July 13, 2017, 05:06:31 pm »
The 6424 has two tone knobs so I won't be tweaking for one knob. Look at the 1624 schematic if you want to see the one knobber version of this amp.
« Reply #3 on: July 13, 2017, 08:27:31 pm »
the schematic you posted on another thread shows 1 knob for each side of V1, so ya 2 total, same as I'm thinking of doing, currently I have 2 per side.
If I looked at it correctly they are the same 500pf, .0033uF, 500k.
I'll steal that as a starting point.
« Reply #4 on: July 13, 2017, 09:36:08 pm »
Subscribed.
Hi Steve - what VA rating is that variac on your bench BTW? (if you don't mind me asking - only it looks like of compact/smallish - like 500VA or something. I was wondering about picking one up for myself, but didn't think that 500VA would be big enough. If it is 500VA, how do you find it for your stuff?)
Offline Joel
« Reply #5 on: July 13, 2017, 10:20:12 pm »
Excellent!
The mouth of a happy man is filled with beer  - Egyptian Proverb
« Reply #6 on: July 13, 2017, 10:39:47 pm »
It's rated for 0-140V and 10 amps. I sold a 5 amp Staco earlier this year. 5 amps is big enough for everything I've messed with. 10 amps is what I've seen mostly in the old repair shops. If I had to buy one I'd shop for a 10 amp model. A built in volt meter is very handy too.
Offline Tony Bones
  • Thread Killer
« Reply #7 on: July 14, 2017, 08:02:06 am »
And, if you would like a variac that does not hum and vibrate, then get one rated for 240V and run it on 120V. Unfortunately, the current rated does not double, it stays the same.
Offline MFowler
« Reply #8 on: July 14, 2017, 09:10:20 am »
Steve,
Great looking project looking forward to this.  I had a custom 1-15 cabinet built and will be tackling a Supro T-bolt one of these days.
Mark
« Reply #9 on: July 14, 2017, 11:06:42 am »
Thanks Mark. I've been following your project over on TAG with interest. Looks good too.
« Reply #10 on: July 14, 2017, 05:29:24 pm »
The original GR Variac was rated 10A. Many clones were also. In days of 15A circuits, a 10A would handle nearly any load. The "10A" is conservative and you can beat it considerable for occasional use/abuse.
Smaller ones don't want to cost a lot less-- wire core and labor don't scale-down real favorably. Of course smaller/larger ones did appear, under 2A to over 30A. I just got a 5A which I plan to use on a 3.6A furnace blower where it may be loaded 23 hours a day. (I ended up with the small fan on the extra-small burner and it blows a lot of hardly-hot air; I can reduce the blow for the same heat in warmed air and less draft.)
« Reply #11 on: July 14, 2017, 08:20:49 pm »
Got the board built today. Too hot to do any more...
Offline EKDENTON
  • never goin back to solid state
    • Pueblo Pipe and Steel inc.
« Reply #12 on: July 15, 2017, 10:35:56 pm »
Real nice looking so far! You always make nice neat looking amps!
You only fail ... if you quit trying.
« Reply #13 on: July 16, 2017, 02:19:23 pm »
I got the board laced and loaded today...
« Reply #14 on: July 17, 2017, 07:58:42 am »
Man you just throwing all the mojo out.  MF Resistors, Illinois caps, and Chicklets?  Have you gone mad sir?  You know it will now sound like a modern Mesa Boogie, is this really what you want being an old surf junkie?
How hot is it?  Why didn't you air condition your workshop?  You've got enough money to air condition a cotton field there in LA.
Is this where you play guitar too?
 :laugh:
Looks great and really a fun amp.  The tremolo is outstanding.  Is that Black Fiberglass Board? It looks like it has graphite on it.
The lone turret under the pot on the front of the chassis, did you not drill through?  Use a bottoming tap.  This support for your preamp ground bus?
« Reply #15 on: July 17, 2017, 10:06:16 am »
I've set my sights pretty high on this one. I'm gonna be able to play the opening to "Whole Lotta Love"!  :wink:
How hot is it?  Why didn't you air condition your workshop?  You've got enough money to air condition a cotton field there in LA. Is this where you play guitar too?
Low 90s with matching humidity. I'm still trying to raise money for an AC unit. Not to worry though. The pool is only 20 steps away. And I have a refrigerator in the shop. I prefer to do amps during the winter.
Yes. Got it from Doug. He calls it FR4/G10. It drills and cuts easier than his green board. The board is jet black but the fluorescent lights put a "washed out" sheen on it. Haven't been able to get a good pic.
The turret is soldered to the back of the pot. It supports the two mixing resistors from the two volume pots. Look at the layout and schematic.
« Last Edit: July 17, 2017, 10:10:37 am by sluckey »
« Reply #16 on: July 17, 2017, 10:47:53 am »
I got an 8ton unit with a couple issues, but it's free :icon_biggrin:
« Reply #17 on: July 17, 2017, 10:59:56 am »
I see the Visio work now, you added it.
Your schematic drawing is much easier and logical to read, but it doesn't show a switching pot.  It took me a bit to find the shared cathode site you have them reversed.  Are you planing a pull pot to slow the tremolo even more or is it simply to stop and start?
I see you have a switching dual input.  I do this a lot now myself ever since the AC15.  Just a simple thing, but it adds so much to the tonal versatility to an amp.  Since the wiggle channel has more gain and headroom, I am surprised you duplicated the tone stack.
I wish I could play :sad2:   Even if it were only Whole Lotta Love.  Finger doesn't look a lot better yet.  120 grit on a belt sander will remove fingernail and skin quick.  I just hope it quits bleeding in a day or 2.
Nice work as always!
« Reply #18 on: July 17, 2017, 11:04:31 am »
Shooter, he is full of more crap than a Christmas Turkey!
Trying to raise money.  Yea, I believe that.  No, he is just used to the Mobile area where when it is not hot, you better leave cause a hurricane is on the way.  I hear the older you get the more you prefer the heat.  I also hear you ears do not quit growing and I already have plenty. :laugh:
« Reply #19 on: July 17, 2017, 12:44:25 pm »
Couple issues??? Are you saying it actually took two lightning strikes?  :l2:
« Reply #20 on: July 17, 2017, 12:53:06 pm »
The pot switch simply turns the trem on/off. Just trying to keep it true to the schematic but mostly it's s good way to mount that 2.2M resistor.  :icon_biggrin:
I got my index finger jammed between a disc sander and the sanding table on my ShopSmith once. It came out once I had sanded it enough.
« Reply #21 on: July 17, 2017, 01:36:47 pm »
Looks like all I'll get done today is the filament string.
« Reply #22 on: July 17, 2017, 01:45:30 pm »
You folks need to sand like you build amps :laugh:
I wasn't counting, I wasn't seeing very well either!  I was upstairs, 30ish ft away when it struck!!  The next morning my eyes felt like I had flash burns from welding!  It also hit 3 apple trees that had been on the property since late 40's.  They have lost most of their bark, most of the upper growth, but still got a bumper crop growing for the resident deer.
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #23 on: July 18, 2017, 11:20:10 am »
Wow I've missed this much of your build Steve!  Good to see another amazing build coming together.  But I do see one error.  You've got the red and black wires used for heaters when they should be green and white! :P
Look forward to the finished product!  My first ever real time sluckey build.
(I missed the first due to being on vacation in Scotland, so I guess that's acceptable :D)
~Phil
Phil Davis
tUber Nerd =|D
« Reply #24 on: July 18, 2017, 11:47:19 am »
I prefer green/yellow and would really love to have some brown. But I have limited quantities of those colors. Got miles of 20AWG red and black Teflon though! That's the main reason I use it. Plus it makes all the Marshall freaks happy!  :l2:
« Reply #25 on: July 19, 2017, 12:51:52 pm »
Got the control panel wired today...
Offline SILVERGUN
« Reply #26 on: July 19, 2017, 02:32:57 pm »
Beautiful, inspirational work, as always..  :notworthy:
Love the way you are able to work patiently and just chip away at it. I always get so damn excited I just work and work until my eyes hurt and I need a massage.
I noticed a small discrepancy in your schematic.
The cathode bypass cap on the input triode ("Z" feed from the tremolo) appears to be 35uf/50V on the original, but .0033 on your schematic. I see where you have a 35uf on your layout, so I'm sure it's just a typo.
I found this while comparing values and circuit structure to the 1624T model.
This 6424 and the 1624T are basically identical.
Your documentation is always perfect and I want to keep it that way  :icon_biggrin:
« Reply #27 on: July 19, 2017, 03:54:08 pm »
Thanks for catching that. Got it fixed already. As always, if you find any discrepancies or other little turds please let me know.
I'm not really being patient on this project. I would be done by now if I had waited until winter to do it. But I got the hots to do it right now. And that's the problem. It's too damn hot and sticky in my shop to stay on the bench for more than a couple hours! I'm working in a bathing suit so I can jump in the pool with a beer. I usually don't make it back to the shop after that!  :icon_biggrin:
Offline CraigB
« Reply #28 on: July 19, 2017, 06:09:16 pm »
Nice project Steve, I've been wanting to build a PP 6973 based amp ever since I "restored" a Gretsch 6161 a few years back.  Looks like pretty much the same beast to me.  The guy had two of them, one that was completely thrashed (mostly the cabinet and speakers, which looked like they had spent some time underwater) and the other amp was in half decent shape, so he commissioned me to salvage the parts that were in the best shape from either and make them into one functioning amp, and whatever was left was spare parts.  So I had never heard played on one of these until I finished the project.  Very impressive little amp and very fun to play.  I must say, I didn't want to deliver it back to him!
« Reply #29 on: July 19, 2017, 08:05:11 pm »
That sounds encouraging. Thanks for the info Craig. Thanks for the kind words as well.
« Reply #30 on: July 19, 2017, 08:26:42 pm »
ok, I give, is that standoff soldered?
and
doesn't that water down the already thin beer :laugh:
« Last Edit: July 19, 2017, 08:29:05 pm by shooter »
« Reply #31 on: July 20, 2017, 12:15:23 am »
Yes. The bottom threaded part is brass. Solders very easy even with my little Weller iron. Just gotta use flux and pre tin the turret and the back of the pot.
« Reply #32 on: July 20, 2017, 04:52:17 am »
Been following this build with interest.  Looks like  fun project!
Offline adamG
« Reply #33 on: July 20, 2017, 05:09:39 am »
Steve,
Regarding my topic of 1624, what power output with your 6424 are you gonna receive?
I think ,I'll follow my build with quartet tube power stage and remain with biasing cathode resistor or resistors.
Regards,
Adam
« Reply #34 on: July 20, 2017, 07:40:57 am »
I'm expecting about 15 watts.
Offline adamG
« Reply #35 on: July 20, 2017, 08:22:11 am »
Acc.to 6973 data, It should be approx. 17W with 300V at plates.
On schematic we have 350V. So, It might be even more?
Regards,
Adam
Offline MFowler
« Reply #36 on: July 20, 2017, 08:35:33 am »
Haven't seen that before, very neat idea. I use a lot of those turrets and think I'll still just drill a hole and bolt mine on, I'd probably cook the hell out of the pot.
Mark
« Reply #37 on: July 20, 2017, 09:04:41 am »
agreed, does seem a waste of good threads though :laugh:
« Reply #38 on: July 20, 2017, 10:58:29 am »
Got the input selector, shielded cables and PT wired this morning. All PT voltages checked out OK. Probably won't get back on this until Monday. Got some dignitaries coming to Mobile this weekend.
    • Daviszone
« Reply #39 on: July 20, 2017, 12:03:32 pm »
In Laws? :)
~Phil
Phil Davis
tUber Nerd =|D
« Reply #40 on: July 20, 2017, 01:00:28 pm »
No, they're outlaws! At least one is.  :icon_biggrin:
« Reply #41 on: July 20, 2017, 01:07:26 pm »
The best kind bring 'shine.
Offline bnwitt
  • Crankin' out the tone.
« Reply #42 on: July 20, 2017, 08:17:53 pm »
Very nice Steve
Offline Joel
« Reply #43 on: July 20, 2017, 09:14:59 pm »
I'm building vicariously via this thread.  It's looking very nice Steve, and I'm finding nice little touches of yours to steal to include on my build.
Speaking of little touches... On your schematic you've got a 1M input resistor, but the layout has 470K.  The original S6424 schematic uses 470K, so I imagine you're also using 470K?  I can't tell from the latest pic...
I'm interested in what output transformer you'll use.  I'm pretty much restricted to the Hammond line of output transformers unless I want to pay an arm, a leg, and my first born to pay shipping from the States.  The Electro-Harmonix 6973EH datasheet gives 17 Watts from 310V plate voltage, 270R Cathode Resistor and 6k load.  The closest Hammond Output transformer would be the 1760H, 6600 ohm CT, 20W.  Of course, this circuit runs the plates a wee bit hotter...
It's the same story with the power transformer.  I'm liking the Hammond 290BEX for this.  315-0-315, 138mA primary.  I reckon this'll give me a B+ of around 350 to 370V when using a 5Y3.
I'll need to break out my books and draw some load lines to figure the difference all these little differences will make.  250R, 310V, 6k vs 270R, 370V, 6.6k.  Or are all these values close enough for rock n' roll?
« Reply #44 on: July 20, 2017, 11:02:33 pm »
the hammond 1650F 7.6k 25W OT is closer to the original supro part which is 7.5k.   :dontknow:
the 290BX will generate about 375V.
« Reply #45 on: July 21, 2017, 05:10:55 am »
Thanks for finding that error. I've corrected it.
I'm using a PT and OT from a donor Hammond AO-43 amp.
« Reply #46 on: July 21, 2017, 10:02:48 am »
And they may bring some of that wacky weed too. :laugh:
« Reply #47 on: July 21, 2017, 10:04:25 am »
Do you know the reflected impedance on the Hammond OT?  I guessed they were 10K/8ohm, but I have never known for sure.
« Reply #48 on: July 21, 2017, 10:40:20 am »
Voltage ratio is 1.025:30.6 or 29.85.
Impedance ratio is 29.85 x 29.85 = 891.
So, 8Ω would reflect 8 x 891 = 7128Ω plate to plate. Looks like a good choice for 6973s.
This OT was used with a pair of EL84s in the AO-43 amp and the same OT was used with a pair of 6GW8s in the AO-44 amp. And I used the same OT in my Plexi6V6 and L'il Maggie projects.
« Reply #49 on: July 22, 2017, 12:01:07 pm »
These are perfect for all of those tubes mentioned. I really like them (the Hammond iron). I've also used it for 6BM8s with much success.
Steve, you inspired me to create an amp conversion recently, as many of your amp projects have - and I'd just like give a big thank you for this along with all of the responsive help you provide. :thumbsup:
