September 13, 2026, 11:27:56 pm
Hoffman Amps Forum image Author Topic: Shielded?  (Read 6083 times)
Offline davidwpack
    • My music on reverbnation
Shielded?
« on: July 21, 2017, 10:50:22 am »
Hey there again. Just gotta quick question. Going from the middle lug of the volume pot to V1-7; should this be shielded cable? I used it from input to V1-2 but wasn't sure if it was necessary for V1-7. Thanks again!...Dave
Re: Shielded?
« Reply #1 on: July 21, 2017, 11:22:15 am »
Not strictly necessary
give a try without
(It depends from many factors)
Re: Shielded?
« Reply #2 on: July 21, 2017, 11:27:39 am »
give a try without
+1
If you do use shielded, use the same "rules" and only ground 1 side, typically closest to the incoming signal
Offline davidwpack
Re: Shielded?
« Reply #3 on: July 21, 2017, 11:43:45 am »
OK. I appreciate the quick responses!...Dave
Re: Shielded?
« Reply #4 on: July 21, 2017, 12:52:09 pm »
Depends on the layout. I would not bother if the run is only 2-3 inches or less. But if the pot is on the front of the chassis and the tube is on the back side, I would use shielded cable. Ground one end ONLY at the pot.
Offline davidwpack
Re: Shielded?
« Reply #5 on: July 21, 2017, 01:05:37 pm »
Yeah, they're on opposite sides. Around 5 1/2 inches probly. Thanks. Sluckey, I was looking at your project. I thought my heater wires looked pretty good till I saw yours. Comparatively mine are awful. Do you use stranded wire for your heaters? Anyways very nice looking work.
Re: Shielded?
« Reply #6 on: July 21, 2017, 01:10:38 pm »
I use 20AWG stranded Teflon insulated wires for all filaments. I like the 19 strands rather than 7 strands.
Offline davidwpack
Re: Shielded?
« Reply #7 on: July 21, 2017, 01:13:31 pm »
Ok. Thanks. More practice I guess, ey?
Re: Shielded?
« Reply #8 on: July 21, 2017, 01:17:28 pm »
Maybe. It takes me a long time to run filaments like that. Filament strings is the least enjoyable part of the building process for me.
Offline davidwpack
Re: Shielded?
« Reply #9 on: July 21, 2017, 01:25:48 pm »
Yep, mine too. Especially when soldering to the preamp sockets.
