August 25, 2026, 12:18:33 pm
Hoffman Amps Forum image Author Topic: Designing a board layout  (Read 5768 times)
Offline warioblast
« on: August 15, 2017, 11:34:49 am »
Can I put B+ parallel to ground ? Is there a safety distance ?
Re: Designing a board layout
« Reply #1 on: August 15, 2017, 11:44:46 am »
Can I put B+ parallel to ground ?   yes
Is there a safety distance ?   It's so small you don't need to be concerned.
Offline warioblast
« Reply #2 on: August 15, 2017, 11:59:13 am »
Steve, once again thank you :thumbsup:
« Reply #3 on: August 15, 2017, 04:27:29 pm »
> a safety distance
Seems to be much less than 0.01" for any likely guitar voltage, and no sharp points.
Obviously the mechanical shake allowance should be much larger.
It is usual to provide 3mm to 6mm (1/8"-1/4") "creepage distance" around line voltages, and this may be a good guide for small tube voltages. Double that for power tube plates.
Offline JB
« Reply #4 on: August 16, 2017, 04:31:15 am »
I think rather than a gap for electrical isloation you need to think about a safe distance such that a meter or scope probe that slips can't touch both.
« Reply #5 on: August 16, 2017, 08:26:45 am »
If there's no coupling problem, you might not have to probe  :laugh:
probing is  always an issue, pin gap on  relay, tube socket, IC, Just like design, thinking ahead 2 steps keeps you outta the ditch.
Offline warioblast
« Reply #6 on: September 01, 2017, 03:58:18 pm »
I've got another one Q.
I read the heater wiring should cross a signal wire at right angle. But can I have the heater wiring in parallel of a hot signal wire from 0.4 inches (1 cm) distance ? They would be parallel for 6 inches (15cm) FWIW.
« Reply #7 on: September 01, 2017, 04:06:03 pm »
Bad idea, especially if the signal wire is a low level preamp signal. But if you are talking about a speaker wire (that's a hot signal wire too) then you should be OK.
Offline warioblast
« Reply #8 on: September 01, 2017, 04:55:04 pm »
They are wires going to the power tubes grids.
« Last Edit: September 01, 2017, 05:01:50 pm by warioblast »
Offline warioblast
« Reply #9 on: September 07, 2017, 09:52:34 am »
What about the heater running along PT B+ ?
I've done it in my previous build but I'm not sure it is good practice.
« Reply #10 on: September 07, 2017, 10:52:08 am »
OK
Offline warioblast
« Reply #11 on: September 07, 2017, 11:08:41 am »
Many THX  :worthy1:
