July 25, 2026, 07:49:01 pm
Hoffman Amps Forum image Author Topic: Blues Junior reverb  (Read 4957 times)
Offline Apprentice
Blues Junior reverb
« on: August 22, 2017, 10:11:27 am »
Just finished installing a spring reverb in my Hoffman Blues Junior. I used the Rob Robinette Ss circuit that is basically the blues deluxe circuit and I suppose is designed for a different tank. It works pretty well though. It just has tons of reverb at anything over 0.5 on the pot.
Anyone had any experience of this design. Or any advice to improve the match of this design to the BJ?
I've inserted the circuit at the 220k resistor at master wiper and before phase inverter basically removing 220k on BJ and replacing it with 220k on the circuit below between dry and wet & dry points. I hope that makes sense!
Re: Blues Junior reverb
« Reply #1 on: August 22, 2017, 10:24:32 am »
do you mean 1/2 way to 10, or 1/2 way to 1 :dontknow:
Offline Apprentice
« Reply #2 on: August 22, 2017, 11:02:34 am »
1/2 way to 1.
Offline Deric
« Reply #3 on: August 22, 2017, 11:25:01 am »
On any Fender reverb circuit (tube or SS) I always use an audio taper pot for the reverb level control as I find the linear taper pots almost always create the same issue you are having.
I added the Blues Jr reverb (different but similar to what you posted) to a 6G2 and had the same issue.  Swapped the linear taper pot for an audio taper and it works very well.
« Reply #4 on: August 22, 2017, 12:51:48 pm »
I circled some R's, ohm out n verify they are what the schematic says they are.
Offline Apprentice
« Reply #5 on: August 22, 2017, 01:50:53 pm »
Ok will check the the Resistors and have a go at changing the pot to and union taper. I'm pretty sure the Rs are ok but will check. Thanks for the help
« Reply #6 on: August 22, 2017, 09:55:35 pm »
Agree: check those values. They don't look wrong on the plan. But stuff goes wrong between plan and build. Red-Red-Green is real different from Red-Red-Yellow (how would I know??)
R36 could be reduced from 220K to 100K to 47K, sure.
A properly gained reverb path should not really need an Audio taper, but it sure will make a too-hot reverb more useful.
