August 29, 2026, 03:04:33 pm
Hoffman Amps Forum image Author Topic: 5F2a blowing 22/50V cap next to 5W cement resistor?  (Read 5763 times)
Offline leevc5
« on: September 23, 2017, 06:14:37 pm »
Plug it in, hear a humming sound then POP...smoke...capacitor debris all over the place.
What could it be?
Re: 5F2a blowing 22/50V cap next to 5W cement resistor?
« Reply #1 on: September 23, 2017, 06:39:37 pm »
A bad cap.
Offline labb
« Reply #2 on: September 23, 2017, 07:36:45 pm »
installed backwards.
« Reply #3 on: September 23, 2017, 11:50:35 pm »
With polarised electrolytic caps, you need to observe the correct polarity. (+ve pole should point to the higher voltage end of the cathode resistor)
« Reply #4 on: September 24, 2017, 10:16:48 am »
Voltage rating is the last thing not mentioned, I've blown up 1 cap when I got in a hurry and put a 350vdc where a 450vdc shoulda been :think1:
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #5 on: September 24, 2017, 12:46:17 pm »
Voltage rating is the last thing not mentioned, . . .
If the 5W cement resistor isn't performing its intended function, the 22/50V cap can charge up well past its voltage rating.
