September 22, 2026, 06:15:20 pm
Hoffman Amps Forum image Author Topic: Kay 803 Grounding  (Read 6350 times)
Offline dpm309
    • Matthews Amps
Kay 803 Grounding
« on: September 28, 2017, 07:33:18 pm »
Want to add a 3-prong plug to a Kay 803 for safety reasons. Amp works fine with no issues. Ran into this discussion about the safety issues in a Kay 703 which is has a different circuit than the 803. http://el34world.com/Forum/index.php?topic=19072.msg195918#msg195918
Here is what I am planning on doing. Would this work?
Re: Kay 803 Grounding
« Reply #1 on: September 28, 2017, 08:01:53 pm »
Looks safe to me.
Offline dpm309
    • Matthews Amps
« Reply #2 on: September 28, 2017, 09:25:10 pm »
Thanks Sluckey will proceed as planned. Wasn't sure after reading the discussion on the Kay 703.
Offline dpm309
    • Matthews Amps
« Reply #3 on: September 29, 2017, 10:18:06 am »
Should the switch be connected to the hot lead instead of the neutral lead? Also would a 1 amp slo-blo fuse be sufficient?
« Reply #4 on: September 29, 2017, 10:20:47 am »
yes and yes
Offline dpm309
    • Matthews Amps
« Reply #5 on: September 29, 2017, 10:40:46 am »
Thank you!
Offline ckilgore
« Reply #6 on: October 04, 2017, 04:18:52 pm »
Is no one concerned that this amp has line ac series heaters?
« Reply #7 on: October 04, 2017, 04:23:08 pm »
> Is no one concerned...
I am, somewhat.
What is your concern? Safety? Yes, we are relying on heater insulation. I'm not keen on that, but it is unlikely to break down. Or tube life? Bah, who cares? These tubes ran OK in my kitchen radio.
