September 08, 2026, 12:19:25 pm
Hoffman Amps Forum image Author Topic: Schaller KV25 tremolo problem  (Read 9243 times)
Offline bibi
« on: November 08, 2017, 09:47:40 am »
Hello,
I have a Schaller KV25 that arrived here in mostly original condition.  Everything checks out ok mostly but I do notice that the tremolo controls don't have much function over the length of the pots throw.  Only at the very end does the depth pot engage for instance.
I have tried to modify the speed and depth pots with more and less parallel resistance but I'm not having much luck still.
I have measured all the voltages and while they are higher than in the original, even when I have brought them down to the level on the schematic, it doesn't sound any different!
If anyone has an idea for what I could try at this point I would much appreciate it!
Re: Schaller KV25 tremolo problem
« Reply #1 on: November 08, 2017, 10:28:36 am »
With trem DISabled, does ch2 have about equal "volume" as ch1?
Offline bibi
« Reply #2 on: November 08, 2017, 11:12:46 am »
thanks for the reply, the normal channel has a slightly larger output than the tremolo channel but not by much
« Reply #3 on: November 08, 2017, 12:48:42 pm »
one of the hard part of "unknown" operation is, what did it do new, or normally?  Was the trem anemic to begin with :dontknow:
I don't see a lot to "fix" short of a rebuild n see.  One "odd" thing for me, F29 wired to the 100k pot wiper.
you could check what appears to be a connector between the 2 BC135s below F29, see if it's corroded, making good connection.  I'll keep scratchin my head :laugh:
Offline bibi
« Reply #4 on: November 09, 2017, 06:30:39 am »
F29 is certainly the LDR!  It is an odd construction-- I thought of replacing it with another type as that has worked for me in the past.  Thanks for idea anyhow!
I have no idea if it was better before or not but now it is basically bad...
« Reply #5 on: November 09, 2017, 08:11:00 am »
replacing it
That would be a good bet!, LDR make sense now, labeling doesn't :think1:
