September 14, 2026, 05:12:57 pm
Hoffman Amps Forum image Author Topic: STINGER BY DENIS CORNELL - ROMANY PLUS  (Read 12142 times)
« on: December 09, 2017, 02:50:44 am »
Hi guys, This is a scratch build I started a very long time ago.
http://www.guitargear.net.au/discussion/index.php?topic=47812.0
I have added a one tube 6BM8 one tube reverb.
I have finally completed this project and thought all was done, took it to a gearfest and got heaps of feedback.
Removed the 6BM8 and found this to be the problem.
Tried a few more valves and problem persisted.
After some mods, this is the circuit now.
Voltages-
pin2 - 15.8v
pin6 - 208v
pin7 - 208v
pin8 - 1.29v
pin9 - 131v
 :dontknow:
Re: STINGER BY DENIS CORNELL - ROMANY PLUS
« Reply #1 on: December 09, 2017, 10:48:48 am »
Increase the 100K from * to #. A lot.
Note that Fender sometimes used 3,300K (3Meg) here, not 100k; which means adding another gain stage.
Resistors go both ways. This "dry" resistor also leaks-back wet signal INto the reverb path.
The Champ-class amp has just about enough gain stock, but adding a reverb path and mixer forces real compromise. Low dry gain, non-wild reverb strength, or extra gain.
« Reply #2 on: December 09, 2017, 01:51:26 pm »
On VOX Cambridge the 3.3M resistor is bypassed with a cap
« Reply #3 on: December 09, 2017, 03:23:05 pm »
Same on many Fenders. This network is just high-enough impedance it will lose treble, so we compensate.
AND the reverb driver is taken from the *second* stage. So much higher signal level, and we can take much more loss on the dry side of the reverb mixer. This loss works both ways: reverb return does not leak-back to reverb input as much.
« Reply #4 on: December 09, 2017, 04:24:48 pm »
SO, It would be much better to insert the reverb off pin1 V1??
« Reply #5 on: December 10, 2017, 12:23:43 am »
Then how are you going to bring the Return back in?
« Reply #6 on: December 10, 2017, 12:30:07 am »
Hi PRR, This is how I have done it.
Works great, with lots of boing.
There is no signal loss or tone loss.
« Reply #7 on: December 10, 2017, 07:14:56 am »
The reverb level pot has dc voltage on it. Does it sound scratchy when you turn the knob?
« Reply #8 on: December 10, 2017, 08:53:59 am »
and the .001 cap between * and 1Ma pot ?
EDIT:
I was looking on the wrong side of the 3.3M resistor  :BangHead: :BangHead: :BangHead:
« Last Edit: December 11, 2017, 08:06:02 am by kagliostro »
« Reply #9 on: December 10, 2017, 12:58:51 pm »
NO scratchy pot that I noticed.
« Reply #10 on: December 11, 2017, 12:44:31 am »
The 0.02u cap could go on the other side of the 3.3Meg.
« Reply #11 on: December 11, 2017, 02:09:37 am »
I'll give it ago. :thumbsup:
« Reply #12 on: December 11, 2017, 03:42:35 am »
WORKS GREAT!!!!!!
PRR, was this insertion point your original thought?
