October 06, 2026, 05:59:15 am
Hoffman Amps Forum image Author Topic: Old field coil Harmony H-195 PT smoked  (Read 5321 times)
Offline okies
« on: January 07, 2018, 06:01:10 pm »
Hi, I'm new to the forum, just purchased some parts from the store and seen the forum and am hoping someone can lend some assistance.
 I have an old field coil style Harmony amp, tubes are 1-6sl7,  1-6c5,  1-6v6  and a 5y3 rectifier tube. When I got it the filter caps were replaced as were several other caps that were leaky, also a few resistors that had drifted. I used the amp for 6 months or so, just off and on for an hour or so at a time. The other day it just wouldnt power up so I checked the fuse and it had blown. I opened it up and checked closely for wire shorts, I removed all the tubes and powered it up, still no luck and now the PT is smoking. I am going to assume at this point the PT is toast and need a new one. My question is how do I determine what PT to buy? There are small 5 watt Valco style PTs available from several sources but I'm not sure if they would work.
Any help would be appreciated.
Steve
Re: Old field coil Harmony H-195 PT smoked
« Reply #1 on: January 07, 2018, 07:38:06 pm »
start with your tubes filament current, add them up for that rating
do you have a schematic?, do you have DC voltage readings when it worked?
If not figure the 6V6 n 5Y3 will probably operate your B+ to something 250-300vdc, and the 6V6 operating SE you can get a ballpark current from the data sheet.  try and figure out what the cathode R is for the 6V6 also.
the BIG thing is why did you PT fry?, bad tube, bad R........you don't want to fry another before you get that one figured out.
Offline okies
« Reply #2 on: January 08, 2018, 06:53:27 pm »
Hey thanks for taking the time, I'll do what you said.
Steve
« Reply #3 on: January 08, 2018, 08:08:58 pm »
That's a Fender Champ, done different (two actual inputs). You can't read the schematic I found, but squinting shows nothing strange.
Uses the PT from a 1935-1950 Big Radio.
Today you buy a "Champ PT".
The power output will be less than a Champ on the same PT, because of field coil drop. That is how these things were, until we had affordable permanent magnets. If the Champ PT gives you a half-Watt less than the original, that's better then zero Watts, and this was never a Jericho amp. But the raw voltages are probably very close, because of the limits of electrolytic caps.
« Reply #4 on: January 08, 2018, 09:03:07 pm »
Here's a better schematic...
