October 06, 2026, 01:55:05 am
Hoffman Amps Forum image Author Topic: First power on question.  (Read 4359 times)
Offline chocopower
« on: February 19, 2018, 04:08:06 pm »
New rebuild amp.
I have no variac, but i use a step down transformer (220v to 120v) so in the first power on, amp get lower voltage. I'm from Spain. 220vac here.
I use too, a current limiter bulb.
My question is:
220vac---step down transformer----bulb---amp
Or
220vac---bulb---step down transformer---amp
I only have 220vac bulbs, so i dont know how they could work after the stepdown transformer.
Thanks in advance.
David
Re: First power on question.
« Reply #1 on: February 19, 2018, 04:21:30 pm »
I suggest 220v to current limiter bulb to amp. Forget about the stepdown transformer.
Offline chocopower
« Reply #2 on: February 19, 2018, 04:39:22 pm »
Thats the way i use to do... but this time im a bit worried about P.T. primary wiring. Is a old amp and wires are  bit confusing im primary side.
I'm 99.99% sure about my work, but in the catastrofic situattion i picked a 120v primary widding, i want to use the step down transformer.....
I realize that i'm being a bit paranoic, but ....
David
« Reply #3 on: February 19, 2018, 05:51:40 pm »
..... 220V line > Lamp Limiter > 220V/110V Step Down Transformer > Amp  (may be ???)
