October 06, 2026, 12:28:31 am
Hoffman Amps Forum image Author Topic: Fender - Model 26  (Read 7347 times)
Offline reddead83
Fender - Model 26
« on: February 20, 2018, 02:29:18 pm »
Hello,
I'd like to build a Fender Model 26. I scoured the internet for a layout but couldn't find one so I decided to try and make my own. Would anyone be willing to verify it for me since this is my first layout?
Thank you.
Jesse
Re: Fender - Model 26
« Reply #1 on: February 20, 2018, 07:11:36 pm »
Missing shorting-finger on Inst 1 Inst 2 jacks.
Missing ground on MIC pot.
Is that a jumper 6N7 plates?
I'll assume pale-green is 6VAC CT.
There's a real difference choke or 25K dropper. Will the 6V6es be happy at the much higher G2 voltage?
Offline reddead83
« Reply #2 on: February 20, 2018, 09:16:16 pm »
Thanks PRR, I appreciate the help.
I revised it.
That is a jumper from Pin 6 to Pin 3 of the 6N7.
The pale green is a CT.
Got the idea for the choke from Uncle Doug on Youtube. He recommended it to quiet down the amp. What would you recommend?
« Last Edit: February 20, 2018, 09:29:47 pm by reddead83 »
Offline MFowler
« Reply #3 on: February 21, 2018, 08:00:11 am »
In this video Uncle Doug is building a home made Model 26 combo.
Mark
« Reply #4 on: February 21, 2018, 08:53:57 am »
Switch terminal on J1 and J2 should be connected to ground just like J3.
Remove jumper between pins 3 and 6 on V2.
Move yellow wire on pin 5 of each 6V6 to pin 6.
Offline reddead83
« Reply #5 on: February 21, 2018, 02:26:56 pm »
Thanks Sluckey. I'm building your Revibe right now. i'll start a thread when I'm done.
I've made the changes. Anything else?
- Jesse
« Reply #6 on: February 21, 2018, 05:53:43 pm »
to my ears, that model 26 doesn't sound good at all. it would be interesting to hear clips of yours. good luck with the build.
respectfully,
Offline reddead83
« Reply #7 on: February 22, 2018, 05:47:41 pm »
I guess we’ll see how it sounds. I thought it sounded great despite Doug’s admitted lack of proficiency on the guitar. I’ll get some clips once I’m done. I appreciate all the help.
