October 05, 2026, 05:57:55 pm
Hoffman Amps Forum image Author Topic: shrink wrapped tube?  (Read 5848 times)
Offline GLFSHNT
« on: March 03, 2018, 07:26:44 am »
The 12AX7 preamp tubes on my 65 Lil Elvis amp have a heavy shrink wrap covering them. One of them also has several large O-rings over the shrink wrap. It looks like the intent is to allow the tube to get as hot as possible.  I have not seen this before. Is this a "known thing" to do with preamp tubes?
I replaced the tubes without all the wrap....  Amp sounds good.
Re: shrink wrapped tube?
« Reply #1 on: March 03, 2018, 07:45:02 am »
I have never seen shrink wrap (I assume you are talking about heat shrink tubing?) placed on a tube, but I have seen O-rings used to reduce microphonics due to tube vibration. That's probably the intended use in your amp.
Offline GLFSHNT
« Reply #2 on: March 03, 2018, 08:28:54 am »
That's possible  one of the 12Ax7s was "bad" microphonic.
I think it was, from the factory with the heat shrink covering.
I send a note to 65amps but have not received a reply.
« Reply #3 on: March 03, 2018, 12:45:16 pm »
Mesa Boogie sells these
« Reply #4 on: March 03, 2018, 01:22:34 pm »
Aw, that's cute. Think I could get some with my name on them?  :icon_biggrin:
« Reply #5 on: March 03, 2018, 02:28:40 pm »
Aw, that's cute.
:laugh:
is that for modesty or safe tubing :icon_biggrin:
« Reply #6 on: March 03, 2018, 02:57:34 pm »
yes
« Reply #7 on: March 03, 2018, 03:05:06 pm »
https://www.heatshrink.com/content/custom-printing.asp
About $0.80/inch for 12AX7-size tube, min order 25 (inches? reels?)
« Reply #8 on: March 03, 2018, 05:50:25 pm »
Thanks PRR, I now know 1pt = 1/72" !  Not too sure I'll retain that :think1:
