October 04, 2026, 03:21:49 pm
Hoffman Amps Forum image Author Topic: blues jr conversion project - bias setting  (Read 5703 times)
Offline rsr
« on: March 03, 2018, 04:35:04 pm »
I'm nearly done with the wiring up of my BJR conversion project.
Prior to the conversion, as i've said, this was a billm modified amp, which is not relevant anymore, except that i am still using the Heyboer TO20 output transformer that i put in as part of the mods.
So my question is, should i use the same bias setting as i was using before, based on that transformer, or is there a different value now, based on the hoffman circuit vs the standard BJR, with the TO20 transformer?
Hope that makes sense.
rsr
Re: blues jr conversion project - bias setting
« Reply #1 on: March 03, 2018, 04:42:22 pm »
Please keep all this BJ conversion discussion in a single thread so there will be some continuity.
Offline rsr
« Reply #2 on: March 03, 2018, 06:47:10 pm »
So i'll take a guess at the answer.
Probably the bias should be the same, since i think it is more of a function of the transformer and tubes than the circuit.
That's how i'll start anyway.
And i was wrong about one thing, i have a TO20B not TO20 which, according to billm (well, not bill, actually, sadly) back when i did the mod was slightly different.
The setting i was using is 3.35v (or so) for the primary voltage drop, and so that's what i'll go with here now, unless somebody has some guidance otherwise.
As to the point about forum/thread/continuity....
In my experience as a forum user (software architect, 30+ year career, lots and lots of forum interactions) I've always found it better to keep a thread focused on a single question or topic, and by and large that is the preferred etiquette in the forums that i've participated in.   While "blues junior conversion" certainly is a topic, i've tried to make a small number of threads that each is focused on some specific question that has come up as i've gone along. (Mostly. I think i bundled a few questions in a single post early on.)
I will, with any luck, have one final post in this saga, which will be a recap of the project. What went good, bad, lessons learned, a suggestion or two for the project link maybe, and so on...   That would, to my thinking, belong in its own thread, along with the discussion that it generates.
One other thing that will be in that summary post, but deserves to be said here as well, is to say a huge thank you to the members of this forum who have responded to my various questions, especially sluckey, for the timely responses to the questions i've asked.  Would have been stuck at the starting line without the help.
rsr
Offline rsr
« Reply #3 on: March 03, 2018, 07:12:05 pm »
I will, with any luck, have one final post in this saga....
That is, assuming the amp works when i turn it on tomorrow (after one more final check).  If it blows up or something, that will lead to an entirely different set of questions...
