October 06, 2026, 01:16:27 am
Hoffman Amps Forum image Author Topic: Super Champ X2 mystery  (Read 5246 times)
Offline matt mincer
« on: March 12, 2018, 02:04:21 pm »
Hey All,
I have a Super Champ that's got an odd problem. The screen grid resistor (R79) burns up intermittently. I'll replace it, check everything and it'll work again for a few weeks. The kicker is, I've actually seen it happen. I cut the old one out and used jumpers to put one in for testing. At some point, it started smoking and burning so I cut the power. When I turned it back on, it was fine again. The voltages to the resistor are fine. The bias voltage is fine. Well, I say that but I haven't been able to test voltages while it's smoking. Does anyone have any ideas? I'm thinking I have a shorted tube but my tester is down so I can't check it.
Matt
Repairing tube amps is cheaper than therapy and better for me than beer.
Re: Super Champ X2 mystery
« Reply #1 on: March 12, 2018, 03:05:45 pm »
Maybe you need a fresh set of 6V6s in the amp. Maybe replace the resistor with a 3W metal oxide resistor or maybe even a 5 or 10 watt resistor. Or maybe C40 is acting up occasionally. My first bet would be the tubes.
« Reply #2 on: March 12, 2018, 03:10:09 pm »
 :laugh:  you keyboard better than me :think1:
Offline purpletele
    • Vallis Enterprises, Inc.
« Reply #3 on: March 12, 2018, 09:24:08 pm »
I reluctantly worked on a Super Champ X2 recently.
I consider myself lucky after removing and replacing the board approximately 10 times due to experimentation, and not breaking any critical parts.
I was sort of frustrated with the time and energy I put into that amp, I could have put a nice Princeton in the Chanp chassis and have a cool amp.
So that is what I am doing now is fitting a Princeton into a Champ as a surprise that he may not get for free, more like $1300.
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« Reply #4 on: March 13, 2018, 07:01:12 pm »
bad solder: check for a bad solder at tubes sockets
P.S.: call me Alvin.
Offline matt mincer
« Reply #5 on: March 13, 2018, 07:36:24 pm »
I put some known good tubes in and let it cook overnight. So far, so good.
Thanks for all the tips.
Matt
