October 06, 2026, 07:44:27 am
Hoffman Amps Forum image Author Topic: bogen chb10  (Read 6847 times)
Offline delux1959
bogen chb10
« on: March 18, 2018, 02:43:45 pm »
I seem to have to many bogens on my hands. This one has a 7868 output tube. Id like to change it to an el84. Is it really as simple as swapping pins 9 and 7?
Re: bogen chb10
« Reply #1 on: March 18, 2018, 02:59:56 pm »
You must consider some other things like B+, the OT impedance and the fact that EL84 (6Bq5) has a lower output power respect 7868
Re: bogen chb10
« Reply #2 on: March 18, 2018, 03:20:30 pm »
No. The sockets are not the same. And you must also consider the electrical characteristics that Franco mentioned.
« Last Edit: March 18, 2018, 03:30:16 pm by sluckey »
Offline delux1959
Re: bogen chb10
« Reply #3 on: March 18, 2018, 06:11:40 pm »
I have a noval on hand I could swap. I looked into the pate voltages on the 7868 and messured 430 vdc with no tube in the socket. Im guessing that is to much for an el84. I was looking at a tube data site and it says max voltage for Va is 300 with a 500vdc peak.
Re: bogen chb10
« Reply #4 on: March 18, 2018, 06:28:12 pm »
put tube in, does it get close to schematic Sluckey posted, that's your "starting" point, my2c, restore it, sell it and buy parts for a 84 build :dontknow:
« Last Edit: March 18, 2018, 08:55:44 pm by kagliostro »
Offline delux1959
Re: bogen chb10
« Reply #6 on: March 18, 2018, 06:43:29 pm »
just got a 7868 on flee bay for $30 including shipping.
Re: bogen chb10
« Reply #7 on: March 18, 2018, 06:45:34 pm »
7868 is funky base 7591 - replace socket with octal socket and rewire for 7591 base. electro-harmonix 7591 is 22 bux.
Re: bogen chb10
« Reply #8 on: March 18, 2018, 07:16:13 pm »
What he said!
Offline delux1959
Re: bogen chb10
« Reply #9 on: March 18, 2018, 09:22:53 pm »
i guess i need to keep looking for a schematic. My amp has an ez80 recto. at least to see what the voltages should be. I thought it was the chb10a.
Re: bogen chb10
« Reply #10 on: March 19, 2018, 12:00:21 pm »
post a few pics?
Re: bogen chb10
« Reply #11 on: March 19, 2018, 12:31:27 pm »
The chb 10 has an ez80 rectifier. The chb 10A is a later version of that same amp. It has the ss voltage doubler rectifier. Other than that change, I bet the amp circuit is very near identical. Do you really need a schematic for this simple amp?
