October 06, 2026, 11:00:59 am
Hoffman Amps Forum image Author Topic: Parallel input - Wich is the better connection to the input jack ?  (Read 5034 times)
The schematic is this
Wich is the better connection way between two tubes and the input jack ?
Only a shielded cable from the input till the first tube then from the first tube to the second tube like in the following layout
or it will be better to have a separated shielded cable (two cables) from input to each single tube ?
« Last Edit: March 21, 2018, 04:59:58 pm by kagliostro »
Re: Parallel input - Wich is the better connection to the input jack ?
« Reply #1 on: March 21, 2018, 04:48:54 pm »
I would mount a single standoff turret between the two preamp sockets. Run a single coax from the input jacks to this turret. Connect the two resistors to this single turret and connect the other end of the two resistors to each tube grid. Think about a "Y", where the coax is the bottom leg and the two resistors are the top legs and the junction is the turret.
« Reply #2 on: March 21, 2018, 05:01:06 pm »
Cool, nice idea
Thanks Steve
« Last Edit: March 21, 2018, 05:03:11 pm by kagliostro »
