September 17, 2026, 11:55:43 am
Hoffman Amps Forum image Author Topic: Insulating pots from chassis  (Read 7143 times)
Offline MikeDL
« on: May 29, 2018, 07:20:36 pm »
In trying to chase down some hum in a preamp I built, I've started learning about ground loops. It seems that the guidance in the library here is to treat the preamp section as a group with only a single ground (often one of the input jacks) and tie all the other input jacks, pots, etc. to that single ground point through a buss wire.
What I'm not understanding is a good way to isolate the pots (alpha, purchased here) from the chassis. I've got shoulder insulators for the jack(s), fibre washers for switches, but I don't seem to find any good way to isolate the pot (especially the shaft going through) from the chassis. I expect I'm missing something, but could someone point me in the right direction?
Thanks!
Re: Insulating pots from chassis
« Reply #1 on: May 29, 2018, 07:50:53 pm »
There is no need to isolate the pot bodies from chassis.
« Reply #2 on: May 29, 2018, 08:08:22 pm »
Ditto.
But if you really want to, I believe a matched pair of these will do the trick for ea pot.  The shoulder washer insulates the pot body from the chassis.  The flat washer insulates the nut.  Not sure if Doug has these.
Mouser.Insulated flat washer 502-S-1028Shoulder Washer 502-S-1029
Offline MikeDL
« Reply #3 on: May 29, 2018, 08:18:02 pm »
OK. Not doubting any advice, just trying to understand the ideas...what then is the purpose of the recommended buss wire soldered to the outside of the pot bodies?
From reading old threads, rounding strategies seem to be a bit of a religious issue.
« Reply #4 on: May 29, 2018, 08:29:17 pm »
convenience, but most have quit soldering to the pots an just make a dedicated preamp-buss
the pot "case" has no connection to the pot, just a chassis for the pot to fit in
« Reply #5 on: May 29, 2018, 08:30:39 pm »
Who is recommending doing that? Fender, Marshall, Sunn didn't do it. I don't do it. And I've never seen anyone insulate the pot bodies from chassis.
« Reply #6 on: May 29, 2018, 08:49:04 pm »
I had the same question when I first joined the Forum.  I agree that there's technically ground loops:  the ground bus wire connects to multiple chassis points at ea. pot body, etc.  But it works.  It's empirically tested & proven.
Offline Sonny ReVerb
  • Possibly another stupid question...
« Reply #7 on: May 30, 2018, 02:41:11 pm »
I think the key is to NOT use the pot body as a ground. Don't solder anything to the back of the pots. If the pots have lugs that are tied to ground, connect them to a buss wire that is subsequently connected to [chassis] ground at a single point (as shooter said).
« Last Edit: May 30, 2018, 02:47:09 pm by Sonny ReVerb »
Offline ginger
« Reply #8 on: May 30, 2018, 03:41:36 pm »
A buss soldered to the back of the pots can be a bit of a mess , if you replace a pot.... but Doug Hoffman DID recommend doing that some time ago
Offline ginger
« Reply #9 on: May 30, 2018, 03:43:33 pm »
I know, without a doubt , that a grounding buss , running from pot to pot is not needed
Offline ginger
« Reply #10 on: May 30, 2018, 03:45:37 pm »
And he showed you how to do it
Offline labb
« Reply #11 on: May 30, 2018, 09:45:41 pm »
Just got to ask, is it 60 cycle or 120?
