September 15, 2026, 04:58:07 pm
Hoffman Amps Forum image Author Topic: E cap broken lead...  (Read 5238 times)
Offline labb
« on: July 20, 2018, 09:39:19 am »
Do you guys support your e caps with RTV? I asked because I just had to repair the first e cap in an AB 763 that I built. The e cap lead had broken right at the solder joint. I know that a lot of manufacturers do this.This is the first time I have had the problem. (Out of some dozen or more amps that I have built)
Re: E cap broken lead...
« Reply #1 on: July 20, 2018, 09:47:00 am »
Look at this recent discussion...
https://el34world.com/Forum/index.php?topic=23498.msg252762#msg252762
I like to use round nose pliers to bend leads. Never had a problem.
Offline labb
« Reply #2 on: July 20, 2018, 10:24:06 am »
Thanks Steve. I always do long radius bends, usually with my fingers. This one broke right at the solder joint of the eyelet..I wonder if I got it too hot and made the lead brittle. Who knows..By the way this is the your AB763 Delux lite that I built. Guy that plays it absolutely loves it. Plays it ahead of a HRD and several other amps that he has.
Offline rake
« Reply #3 on: July 21, 2018, 07:53:55 am »
Heating copper actually anneals it. Quenching or slow cooling after makes no difference.
Copper "work hardens". Even vibration will harden it.
Solid state has no soul........
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #4 on: July 23, 2018, 03:58:46 pm »
Sometimes it just comes down to a manufacturing defect.  It may have just been a dud that required 2 bends to make it break :D
~Phil
Phil Davis
tUber Nerd =|D
« Reply #5 on: July 23, 2018, 07:27:04 pm »
I use silicone glue or spongy double stick tape - never had a problem.
