August 14, 2026, 11:23:39 pm
Hoffman Amps Forum image Author Topic: Modification Of a Guitar Amplifier Circuit.  (Read 5700 times)
Offline slash1986
« on: July 29, 2018, 11:30:14 am »
Hello everyone, I'm here because I need your help.
I have this guitar amp: jetcity JCA20H.
This is the link to the machine diagram.
I would like to modify the circuit a little, to get the sound and distortion typical of marshall amplifiers.
Do you have any advice?
Thanks so much.
Re: Modification Of a Guitar Amplifier Circuit.
« Reply #1 on: July 29, 2018, 12:01:13 pm »
Is this on a PCB board?   What speaker are you using?
« Reply #2 on: July 29, 2018, 12:08:24 pm »
take the part of yours I highlighted and make it look more like the example
blending V1 make's it better than Marshall did  :icon_biggrin:
you already have a DCCCF driving the TS
the bigger ? what marshall type, can you buy a broke one and fix it instead of breaking a good amp you can't fix  :dontknow:
Offline slash1986
« Reply #3 on: July 29, 2018, 12:21:26 pm »
Yes is on PCB. I use a Celestion Vintage 30. When i record the Amp i use a reactive load box with impulses.
Offline slash1986
« Reply #4 on: July 29, 2018, 12:30:48 pm »
jcm800 style.
Yours is definitely good advice.  :w2:
« Reply #5 on: July 29, 2018, 06:28:45 pm »
I wouldn't go that far  :icon_biggrin:
after 21 "builds" 5 of which are commercial-ish, doing the mixing with V1, driving, or recovering the TS with a DCC,CF has impressed the guys with guitars the most.
that said, basterdizing a pcb can and WILL cause you greif, but if you take your time and can solder well, maybe even use "add-on" pcb chips, it's very doable
Offline slash1986
« Reply #6 on: July 30, 2018, 02:48:13 am »
What could happen if I did this:
could I use another valve a new input and bypass the first valve in the circuit?
