August 15, 2026, 12:13:13 am
Hoffman Amps Forum image Author Topic: Layout grounding differences?  (Read 4156 times)
Offline Oddvar
« on: July 29, 2018, 01:03:53 pm »
Hi.  Could anyone elaborate a bit on the differences in grounding on these two layouts?  It seems like the Mojotone connects the the 16uf/450v to the ground bus, the other doesn't?
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
Re: Layout grounding differences?
« Reply #1 on: July 30, 2018, 01:00:42 pm »
Generally separating your preamp sections away from your power sections can reduce the chance for ground loops, but both are proven methods that work (the ceriatone uses one single star ground, and isolated input jacks  instead).  If you're curious about learning more about grounding techniques, I highly recommend you read this chapter of the valve wizard's book he's got on line for free:
His book is worth it anyway, so if you like that chapter go buy the book :D
~Phil
Phil Davis
tUber Nerd =|D
