August 26, 2026, 04:00:04 am
Hoffman Amps Forum image Author Topic: Advise on repairing PT wires  (Read 4514 times)
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« on: August 10, 2018, 02:40:38 pm »
I got PT from an reel-to-reel Geloso 268, the wires crumbled as it was removed from the chassis.
I thought about cutting the soldering new wires, what would be the best way to repair the wires?
See pictures:
https://soundcloud.com/ukiuki
Re: Advise on repairing PT wires
« Reply #1 on: August 10, 2018, 02:52:02 pm »
Gently slice and peel the paper back.  Maybe you can see where they emanate from the coil and replace them.  Or cover with heat shrink tubing.
These rubber insulated leads can probably be replaced.
« Reply #2 on: August 11, 2018, 04:08:14 pm »
Jjasilli is right. Or, you can install lug strips close to the PT when you mount it, and make very short runs to the strip, then new wire from there. I'd still cover with heat shrink or spaghetti tubing though. Bare HT wires sceer me.
Offline uki
    • Uki's Guitar Trip
« Reply #3 on: August 12, 2018, 01:29:20 pm »
Thanks guys !
