September 15, 2026, 07:53:19 am
Hoffman Amps Forum image Author Topic: carvin mts 3200 input output jacks  (Read 5227 times)
Offline Tedfeast
« on: August 24, 2018, 10:56:03 pm »
hello all!!
hope this is the right thread for my question!!
im new to this forum and i hope i can find the answers im seeking!!
ive got a carvin mts 3200 head which i purchased new back in  or around 1997-98.
been a great amp for me..i have read where some folks dont like em, well too bad, its been my tone since i purchased it.
anywhooo..
im having issues with two of the jacks...one of the speaker outputs, and the footswitch input(which is a stereo jack).
after investigating and eliminating several possibilities im fairly certain the issue is worn contacts inside the actual jacks..
my problem is this....carvin, as many of you know has gone the way of the dinosaur, and what remains is of little value...i contacted them, no parts available.
the jacks look to be standard fender style, sealed jacks, the black box kind,  but the parts list from carvin has them as having fewer contact points than the fender ones...carvin says 3, fenders are 4 for mono, carvin says 7 fender says 9 for stereo...
so my questions are these:
1) are these jack the same, and only wired for the lower number of contacts?
2) can i open the housing of these up to bend the contacts back into place without destroying the jack itself?
3) does anyone have any other resource for these jacks, or know or have any parts from this amp laying about that theyd be willing to sell?
sorry for the long story, just want to save my amp..
i've got a local guru who has worked on it in the past, but i was hoping to deal with this job on my own.
im handy with a soldering iron and this isnt a super big job....but i digress
i thank you all in advance for taking the time to read this and look forward to any and all help you may have!!!
« Last Edit: August 25, 2018, 05:20:09 am by tubenit »
Re: carvin mts 3200 input output jacks
« Reply #1 on: August 25, 2018, 07:06:03 pm »
Welcome!
Some of us know some electrics, but are not familiar with the Carvins. Do you have links to schematics? Pictures of these many-leg jacks?
« Reply #2 on: August 26, 2018, 12:23:32 am »
i am familiar with that model amp - they use an odd offset cliff brand jacks.
http://www.cliffuk.co.uk/products/jacksockets/s4.htm
the input jacks are, IIRC, the model CL1312 - can't remember it they're 15mm or 17.5mm height. click on the PDF icon on the CL1312 - you're jacks are 1/4" S4 internal thread.
i would imagine that the send/return are same. the footswitch is standard two button type with a stereo jack TRS.
compare what you have to the jacks offered on that URL and you'll likely find the correct match(es).
btw - i mod the distortion channel - not a fan of the stock zener diode clipping configuration or the low volt DC filament on V1-V3.
good luck with yours.
« Last Edit: August 28, 2018, 11:38:43 pm by DummyLoad »
Offline Tedfeast
« Reply #3 on: August 28, 2018, 08:58:07 am »
Thanks for the input !!
I'll be opening the head up again this week and I'll take some pictures to post.
Hopefully I'm on the right track now!!
« Reply #4 on: August 28, 2018, 11:37:57 pm »
you likely already have it, here it is anyway for the rest.
https://el34world.com/charts/Schematics/files/Carvin/Carvin_mts3200_reve.pdf
sorry - it's a diode clipping ckt. not zener diode clipping ckt. apologies for any confusion.
