September 15, 2026, 02:12:01 am
Hoffman Amps Forum image Author Topic: Marshall jmp 1H very low volume  (Read 4064 times)
Offline jerrydyer
  • Make it one of a kind
« on: August 25, 2018, 02:06:48 pm »
This thing is driving me crazy. Acts like bad O.T. had one so i swapped it. Same. Every single resistor is good. I have not checked every single cap. Just curious if there is already a known issue. I havent been here in a while. Im working for a service center that does repairs for so cal guitar centers. How you guys doin?
« Last Edit: August 25, 2018, 02:16:26 pm by jerrydyer »
Re: Marshall jmp 1H very low volume
« Reply #1 on: August 25, 2018, 08:54:11 pm »
Hey Jerry, good to see you back!
When you say acts like - Distorted output? No sound? Does the power mode switch still make a difference? Also check tension and clean speaker jack contacts.  I'm sure you did the tube wiggle to clean those up too.
Offline jerrydyer
« Reply #2 on: August 25, 2018, 09:06:20 pm »
  • The sound is good just low. And yes there is a slight change in hi and loe powervswitch
