September 15, 2026, 09:59:58 am
Hoffman Amps Forum image Author Topic: Fender Tonemaster channel switching Pop!  (Read 5683 times)
Offline bibi
« on: August 29, 2018, 10:47:58 am »
Hello,
I am currently working on a Fender Tonemaster amp and it has a problem with the switching relays between the two channels-- namely it pops.
The circuit as can be seen from the schematic included is minimal at best-- +24V going to the relay and a 4148 diode across.  I have found reports
of this being a problem from the beginning and no wonder!
Is there any known Fender service repair notice for this amp that I haven't found?  I could modify it pretty easily to be an adequate circuit if that is
the best solution.
Thanks for your help!
Offline VMS
Re: Fender Tonemaster channel switching Pop!
« Reply #1 on: August 29, 2018, 01:55:55 pm »
This schematic shows R66 2M2 resistor after the relay and before the PI:
https://el34world.com/charts/Schematics/files/Fender/Fender_tonemaster.pdf
« Reply #2 on: August 29, 2018, 02:27:18 pm »
Bruce Zinky was eventually fired, so I heard.
Offline bibi
« Reply #3 on: August 30, 2018, 12:29:53 pm »
Well the schematic I posted is a Revision E so that should have addressed some of these issues as it is later than the one on this website.
Unfortunately, it looks likely I will have to do some modifications to get it halfway decent.
