September 18, 2026, 07:38:36 pm
Hoffman Amps Forum image Author Topic: IEC punch  (Read 15161 times)
Offline Sonny ReVerb
  • Possibly another stupid question...
IEC punch
« on: September 16, 2018, 07:14:23 pm »
I finally had a chance to try out my IEC punch that I got from Newark. It did a fine job. I would give it a 'thumbs up' overall.
 One problem, however, is the round body. There's no way to tell if the punch is square to the chassis. I made some pencil marks on the sides of the body that I could align with a center line on the chassis. That did the trick.
https://el34world.com/Forum/index.php?topic=21836.msg233638#msg233638
Offline brewdude
Re: IEC punch
« Reply #1 on: September 22, 2018, 10:07:04 am »
How much did that punch set you back?
Re: IEC punch
« Reply #2 on: September 22, 2018, 10:17:53 am »
Put some lines on the inside of the chassis. Or just use a machinist square to line up the rectangle body on the inside of the chassis. Or cut a 2-1/2" wide board to about 4" long and use that as a guide inside the chassis. Lots of ways to make sure it's square to the chassis, but they all involve the inside of the chassis.
Re: IEC punch
« Reply #3 on: September 24, 2018, 12:55:22 pm »
Currently $77.54. Not cheap, but I haven't seen one cheaper.
https://www.newark.com/duratool/974-0010/rectangular-hole-cutter-28mm-x/dp/55T8294
Offline badamp
Re: IEC punch
« Reply #4 on: October 08, 2020, 11:48:43 am »
Apologies for replying to an old topic. Does anyone know if these IEC punch are still being manufactured ? Newark/RS have discontinued them.
TIA.
Offline Latole
Re: IEC punch
« Reply #5 on: October 12, 2020, 12:39:43 pm »
« Last Edit: October 12, 2020, 12:54:25 pm by Latole »
Re: IEC punch
« Reply #6 on: October 12, 2020, 08:10:08 pm »
for IEC inlet, the punch below would work - at least for the schurter brand IEC type C14 inlet. $500 to $950 american. greenlee makes the one for $500, but no one seems to stock it.
http://www.panelpunches.com/md-07911106r0118
https://www.greenlee.com/us/en/punch-unit-rect750x114191x290-60031?w=2&c=161&b=86&t=6&r=30&p=1&lat=30.336821&lng=-97.707614&l=4&v=c
https://store.phonetx.com/80004939.html
