September 19, 2026, 07:11:28 pm
Hoffman Amps Forum image Author Topic: Heater resistor burnout  (Read 5789 times)
Offline Oddvar
« on: September 22, 2018, 09:04:29 am »
Hi.  Does anyone know what causes a heater resistor to burn?  It seems to be a 470R 3.75w Dale Vishay in this Mesa Boogie Mark IV.
And could I change it with a 470R 5w resistor?
Re: Heater resistor burnout
« Reply #1 on: September 22, 2018, 09:21:45 am »
excess current more than likely burnt it
I only have the MKII schemo, it shows 100ohmers like most builds if that helps
Offline Oddvar
« Reply #2 on: September 22, 2018, 09:58:29 am »
Here is a pic, clearly burnt...
« Reply #3 on: September 22, 2018, 10:06:32 am »
That's not a heater resistor. It's a screen grid resistor. Excessive screen current burned it up. Most likely a bad tube.
Offline Oddvar
« Reply #4 on: September 22, 2018, 10:15:14 am »
It is 470R, 3.75w for some reason.  I was wondering if wattage could go up to five.  And if it could/would be the power tube that caused the failure?
« Reply #5 on: September 22, 2018, 10:21:33 am »
...if it could/would be the power tube that caused the failure?
Offline Oddvar
« Reply #6 on: September 22, 2018, 11:35:52 am »
You're right, I thought it was number 7, blame it on the bad eyesight...
