September 08, 2026, 03:34:38 pm
Hoffman Amps Forum image Author Topic: DIY layout Creator Youtube Video how to's  (Read 89404 times)
« on: August 30, 2018, 02:31:07 pm »
Check out the DIYLC videos I made in the playlist link below.
New video added on 04/02/2024 - Go down to last post below
The videos show you how to create a board in DIYLC
Add components like resistors, caps and wires to your board
Load your board into my on line program
Analyze your board and tell you about any errors you may have
Then you can submit your board to me to have it made on my CNC machine
I have a .diy Template File you can use to create boards that can be cut on my CNC machine
You can import this files into a current .diy file and then copy and paste them where you need them
Hoffman .diy template file is here
https://el34world.com/Forum/Files/Hoffman_Template_File.diy
.diy file library is here
Here's the .diy file library index page
My DIYLC Youtube video playlist is here
https://www.youtube.com/playlist?list=PLVvDFekIYJjeQX4On2q6w4f-nuicAhgpN
« Last Edit: April 02, 2024, 08:37:11 am by EL34 »
« Reply #1 on: September 13, 2018, 01:15:54 pm »
Video #2
More DIYLC setup info
« Last Edit: November 09, 2018, 10:45:06 am by EL34 »
« Reply #2 on: September 13, 2018, 01:16:21 pm »
Video #3
Info on my on line .diy file analyzer program
After you create your .diy file and you want to have a custom board made, you use the analyzer program to make sure everything is ok with your file.
Then you can submit the file and add your custom board to my shopping cart if you want to have it made
All boards are made on my CNC machine   :icon_biggrin:
« Last Edit: November 09, 2018, 10:50:05 am by EL34 »
« Reply #3 on: September 24, 2018, 12:59:41 pm »
I added a new video today that shows how to use a new feature
You can now add cut lines to have long boards cut into shorter boards
I do a quick recap on creating the board in DIY Layout creator
Then analyzing the board in my on line program
Then adding the board to my shopping cart
Video #4
« Last Edit: October 01, 2018, 11:31:28 am by EL34 »
« Reply #4 on: September 27, 2018, 09:55:51 am »
Video #5
Here's how you can add a layout diagram image as a background image in DIYLC
Then you can add holes and components on top of the image
You could then have your custom board made on my CNC machine using your layout
« Last Edit: October 21, 2018, 05:46:41 am by EL34 »
Re: DIY layout Creator Youtube Video how to's
« Reply #5 on: October 04, 2018, 11:50:14 am »
Video #6
I take one of Rob Robinette's really nice .diy files and show how to create a version that can be analyzed with my on line DIY Analyzer program
Here's a link to Rob's page
https://robrobinette.com/DIYLC_to_Circuit_Board.htm
Here's the video link to my you tube video
« Last Edit: October 04, 2018, 12:09:03 pm by EL34 »
« Reply #6 on: December 29, 2018, 04:42:51 pm »
Here's a much better video I did showing what all the menu items do
Plus Variants and Building blocks info
Importing and Exporting Building Blocks and Variants
« Reply #7 on: February 27, 2019, 10:23:28 am »
Here's a new video on how to Import and Export building blocks and variants in DIYLC
« Reply #8 on: March 11, 2019, 11:56:47 am »
How to add a background image to DIYLC
Then add terminals on top of the image to create a custom board
How to add a .diy custom board to my shopping cart
« Reply #9 on: July 12, 2019, 01:20:58 pm »
I just made it way easier to add a custom .diy board to my shopping cart
Watch this video
« Last Edit: July 12, 2019, 02:13:52 pm by EL34 »
« Reply #10 on: December 31, 2019, 05:04:13 pm »
I just did a new DIYLC video that goes through all the menu options
Here's the link
« Reply #11 on: February 08, 2020, 06:24:13 am »
Modifying an existing Fender .diy file and creating a custom board
« Reply #12 on: May 11, 2020, 12:51:32 pm »
How to:
Grab an image from the web
Edit it and add a transparent background
Add the image to DIYLC
Scale the image properly
Add wire connection points to the image
Make the assembly into a building block that you can use for future projects
[/youtube]
« Reply #13 on: April 02, 2024, 08:34:20 am »
Here's a new video on creating custom eyelet and turret lug boards
