September 14, 2026, 05:18:46 pm
Hoffman Amps Forum image Author Topic: Plexi 6V6 - setting the bias  (Read 7271 times)
Offline Big_Mike
« on: December 12, 2018, 11:50:49 am »
Hey guys -
I just finished up the Hoffman 6V6 Plexi.  I have not fired it up yet, but I know I need to set the bias.  From Hoffman's board install instructions, it looks like I need to first fire up the amp without tubes.  Then I need maximize the amount of negative voltage to pin 5 on the power tubes.  Second, I need to add the tubes, then measure the milliamps across the 1 ohm resistors going to the power tubes?  And the reading should be in the 25 milliamp range for 6V6s?  Just wanted to check before I start doing my readings.  Thanks.
Re: Plexi 6V6 - setting the bias
« Reply #1 on: December 12, 2018, 12:03:58 pm »
Set your meter to measure millivolts across the 1Ω resistors. 1mV represents 1mA.
Offline Big_Mike
« Reply #2 on: December 12, 2018, 01:25:45 pm »
Thanks for the info.  Also, would it make sense to add a bleeder resistor to the circuit for safety purposes?  If so, what resistor value should I add?
Offline dude
« Reply #3 on: December 12, 2018, 01:45:26 pm »
Yes, use a 2 watt 220K, from first filter cap to the cans neutral. The bleeding R will run the voltage down pretty fast, about a minute or so when you turn the amp off, but always check first.
al
Offline Big_Mike
« Reply #4 on: December 12, 2018, 03:40:26 pm »
Just to be clear, to install a bleeder resistor, would you run it from where point "A" on the layout to ground, or would it be better to run a resistor to ground from point "E" on the layout?
« Reply #5 on: December 12, 2018, 04:01:16 pm »
Point A. I would physically mount the resistor on the cap can.
Offline Big_Mike
« Reply #6 on: December 13, 2018, 09:16:47 am »
Good idea, I could just run the resistor from the positive terminal to the negative terminal to ground.
Offline dude
« Reply #7 on: December 13, 2018, 10:44:11 am »
Just put the bleeding resistor on the first filter cap tab (point A), where it comes from the standby, the first cap can has two, 32uf legs and a neutral tab, a 2 watt 220K from the first 32uf tab to the neutral tab, very short distance. Of course the neutral tabs on both cans also go to ground.
Offline cboysen
« Reply #8 on: December 20, 2018, 12:09:36 pm »
For your particular build, may I suggest using a very simple heater elevation circuit instead? it will act as a bleeder resistor, and at the same time decrease hum and relieve some strain on the cathode follower - A three for one deal, only using 2 resistors and a capacitor.
/christian
