September 08, 2026, 03:50:46 pm
Hoffman Amps Forum image Author Topic: Gibson Falcon GA19RVT - FILTER CAPS      (Read 5397 times)
Offline Geezer
« on: June 18, 2005, 05:22:42 am »
        > Gibson Falcon GA19RVT - FILTER CAPS
<< Prev Topic | Next Topic >>
Author  Comment
Drewa
Junior tube assistant
(3/15/04 5:13 pm)
Am trying to find new filter caps to replace what look to be original capicators in a 62 Gibson Falcon. The originals read Syncro EPB25348 and have three wires (red 20MFD@450volts, blue 10MFD @ 450volts, black ground) running out one end and nothing running from the other. After looking high an low on the net, I am getting the feeling that these are no longer made.
Can anyone out there please tell me what would be the appropriate replacement for these and, if different, how would they install?
Thanks for the help
Drew
6G6
(3/15/04 6:43 pm)
  Re: Gibson Falcon GA19RVT - FILTER CAPS
Doug sells axiel lead Sprague caps in 10uf/500V and 20uf/500V flavors.
You may have to think about how to fit them in, but they'll work fine for you .
HStraub
Senior tube assistant
(3/15/04 8:03 pm)
Drewa, First, Welcome.
You are correct, that cap is no longer made. Even if you found one, it would be old stock and long dried out by now.
To replace those you have two choices, use standard axial electrolytics and place them inside the chassis or if you want something more original(but still new) check out 'Antique Electronic Supply' (www.tubesandmore.com). Go to their capacitor page, click on electrolytics and then click on multi-section. They carry the widest selection of multi-section caps, twist-lock, radial(similar to what you have) and can type caps. You can find something there to fit in/on the chassis.
Good luck
6G6
(3/16/04 8:10 am)
Mouser carries some cap clamps that would securely mount a can type inside you chassis.
Drewa
(3/16/04 9:26 am)
  Gibson 62 Falcon
 Thanks for the help guys
 Topic Commands
Powered By ezboard® Ver. 7.32
