September 15, 2026, 08:53:06 am
Hoffman Amps Forum image Author Topic: Single Channel, No Reverb, No tremolo AB763 Amp Design  (Read 6876 times)
Offline robrob
« on: March 02, 2019, 01:05:11 pm »
I know this has been done before but here's my take on an easy to build, normal channel only, no reverb, no tremolo AB763 amplifier. There is a 2x6L6 and 2x6V6 version along with a 1 watt micro version that uses the AB763 preamp and phase inverter but feeds a single 12AU7 push-pull power tube.
https://robrobinette.com/RR763_BLACKVIBE.htm
The webpage explains my design decisions and fully documents the amps.
RobRobinette.com
Re: Single Channel, No Reverb, No tremolo AB763 Amp Design
« Reply #1 on: March 02, 2019, 02:10:20 pm »
Thank you for sharing this!
« Reply #2 on: March 03, 2019, 08:34:55 am »
Note that it may be beneficial to connect the PT HT CT wire directly to the reservoir cap's negative terminal, thereby avoiding the heavy ripple current in that circuit contaminating other 0V returns. See section 15.3 of http://www.valvewizard.co.uk/Grounding.pdf
Specifically -
To minimise the interaction of ripple current with the rest of the circuit, the transformer-rectifier-reservoir must be treated as a single, selfcontained circuit block.
Offline robrob
« Reply #3 on: March 03, 2019, 11:04:19 am »
Thank you for that suggestion, I'll make that change pdf64.
RobRobinette.com
Offline vampwizzard
    • Walbertedwards.com
« Reply #4 on: March 03, 2019, 03:41:57 pm »
Id love to hear any sound samples on these if theyve been built. Thanks for more great info!
Offline ALBATROS1234
« Reply #5 on: March 04, 2019, 09:59:52 pm »
good one, i like it. been planning on building a micro type but was thinking of using a 6sn7 instead of 12au7 but i have a couple other tubes i may try 6BL7, 6BX7 and/or 12BH7. i like the idea of the above mentioned 6 volt tube because they are octal.
Offline Papa Jim
« Reply #6 on: March 04, 2019, 10:22:46 pm »
My 5F2 princeton was built into a chassis that had extra sockets, pots, and switches. I have the trannys for the scaled back AB763.  I may just use that princeton build and convert it into this amp. The preamp is very similar just a different tone stack, and bright switch basicly. The extra sockets were left in the chassis. I may just do it.
