September 18, 2026, 11:31:19 pm
Hoffman Amps Forum image Author Topic: Same o'le, same o'le.  (Read 6787 times)
Offline Papa Jim
« on: March 14, 2019, 08:28:20 am »
Another Blue's Jr. redplating V6. Working on a friends amp. Also output sockets have melted solder on their terminals. It has -11.7 vdc on the R31, R32 and they both ohm fine. Is there anything else I should check before resoldering the sockets and trying it again? Watched BillM video on Jr. bias and at 1:40 point I'm not understanding what he does. The amp did not have the voltage that he talked of either. He gives no help what to do if it fails that test.
Re: Same o'le, same o'le.
« Reply #1 on: March 14, 2019, 08:38:19 am »
It's important to check for bias ***DIRECTLY*** on pin 2 of the socket. Even better to check it on the top side of the socket.
Offline Papa Jim
« Reply #2 on: March 14, 2019, 08:56:42 am »
Good point Steve. After seeing the socket connections I know why now. I think I will fix up the socket connections. (some traces may need replaced with wire from the socket to the between socket and main board  flex cable. Then recheck the bias.
Offline Papa Jim
« Reply #3 on: March 15, 2019, 07:20:27 am »
Fixed traces. Not tried. It has .003 uF piggybacked to R20 with amatuer soldering  :dontknow: :dontknow: Why I wonder?  Removed it. Next step, retry bias.
schematic location section/area  C-5 pre PI/master volume.
https://el34world.com/charts/Schematics/files/Fender/Fender_blues_junior_rev_a.pdf
« Last Edit: March 15, 2019, 07:45:57 am by Papa Jim »
Offline Papa Jim
« Reply #4 on: March 15, 2019, 09:45:18 am »
Not redplating now. Bias  -10.74 vdc. Amp no loud.  Looks and smells like OT may have go hot in the past. Probably need to get new output tubes and OT. What ya think.
Offline Slimtim
« Reply #5 on: March 15, 2019, 08:18:49 pm »
do you have any other el84 tubes you can try?
Offline Papa Jim
« Reply #6 on: March 15, 2019, 08:26:28 pm »
Nope I sure don't unfortunately.
Offline Slimtim
« Reply #7 on: March 15, 2019, 08:31:41 pm »
what do you get at tp 17 and 18?and are you saying you're getting low sound or no sound at all?
« Last Edit: March 15, 2019, 08:39:02 pm by Slimtim »
Offline Papa Jim
« Reply #8 on: March 15, 2019, 08:42:47 pm »
Like a 1w bedroom amp volume. It can remain dimed in a bedroom.
« Last Edit: March 15, 2019, 09:27:53 pm by Papa Jim »
Offline Slimtim
« Reply #9 on: March 15, 2019, 08:53:09 pm »
well i dont know much about this stuff but if all your test points are checikng out ok id say its a tube.
Offline Papa Jim
« Reply #10 on: March 23, 2019, 06:35:44 pm »
Got it working with volume now. It was the OT. It evidently got too hot at one time or another. Went ahead and replaced the output tubes just to be sure since I have no idea how long the guy let them redplate for. Anyway all is good.
Offline Slimtim
« Reply #11 on: March 23, 2019, 10:28:46 pm »
damn i hate that it was the trans.
Offline Papa Jim
« Reply #12 on: March 24, 2019, 05:52:40 am »
Yeah, I got to looking and there was some black stuff that was coming out of the old one.
