September 21, 2026, 03:16:47 am
Hoffman Amps Forum image Author Topic: Pin 3 measurement  (Read 4266 times)
Offline pbman1953
Pin 3 measurement
« on: March 15, 2019, 09:43:53 am »
I just learned that my Bias Rite needs a tweak. The meters' power voltage reading is off compared to a stand alone meter.   The Weber company told me about the  trim pot inside the BR to help me match to the stand alone. What started this is that , on my Traynor, pin 3 was 55 volts higher using a stand alone multi meter. It measured around 609 volts vs. the BR was at 552-554.
Due to this I have to take another look at my Sunn 300.
Here's a couple  questions-
Can I pull one tube on the Sunn to read pin 3?
If yes, should I check each socket, pin 3, to see they are the same.
Re: Pin 3 measurement
« Reply #1 on: March 15, 2019, 09:51:45 am »
You need the tubes plugged in to get a meaningful voltage reading.
Offline pbman1953
« Reply #2 on: March 15, 2019, 09:59:21 am »
ok, good info.
I suppose I can test while plugged in.
