September 18, 2026, 11:58:15 am
Hoffman Amps Forum image Author Topic: Musicson 80+80  (Read 8110 times)
Offline chocopower
Musicson 80+80
« on: March 17, 2019, 03:10:43 pm »
Hi there.
I get this old stereo pa system.
Still in refurbishing state, but i found something really weird.
It uses a protection system in case you run the amp without a speaker connected.
Seems, to me, that in case of unloaded secondary,  there are a kind of relay that blow a fuse in the EL34 cathodes.
The relay is the 2 arrows you can see connected to el34 plates.
My question.
Is that arrangement safe in modern standards,  or should i remove it.
Thanks in advance.
« Last Edit: March 17, 2019, 03:12:58 pm by chocopower »
David
Offline chocopower
Re: Musicson 80+80
« Reply #1 on: March 17, 2019, 03:38:33 pm »
Pic.
« Last Edit: March 17, 2019, 04:13:37 pm by chocopower »
David
Re: Musicson 80+80
« Reply #2 on: March 17, 2019, 06:00:15 pm »
That's a Spark Gap. If plate voltage goes high enough, it arcs to ground. (IMHO, this may cause more trouble than it cures.)
Offline chocopower
Re: Musicson 80+80
« Reply #3 on: March 17, 2019, 06:24:44 pm »
Ok. I'll remove it.
Should i keep the cathode fuse?
David
Re: Musicson 80+80
« Reply #4 on: March 17, 2019, 08:46:11 pm »
yes, keep cathode fuses.
Offline chocopower
Re: Musicson 80+80
« Reply #5 on: March 18, 2019, 01:38:42 am »
Thanks both!
Next, work in a readable schematic.
David
Offline chocopower
Re: Musicson 80+80
« Reply #6 on: March 20, 2019, 06:41:48 pm »
Another question.
Main bias pot (there are 2 more balance bias pots), is locate in the AC side of the line, before the reverse diode.
Any problen here?
(I google-it without success)
David
Re: Musicson 80+80
« Reply #7 on: March 20, 2019, 07:21:56 pm »
That's unusual but no reason to not work. Can you draw a schematic of that bias circuit?
Offline chocopower
Re: Musicson 80+80
« Reply #8 on: March 20, 2019, 07:47:48 pm »
Schematic at first post
David
Re: Musicson 80+80
« Reply #9 on: March 20, 2019, 08:03:17 pm »
That's fine. Where are the 2 more balance bias pots you mentioned?
Offline chocopower
Re: Musicson 80+80
« Reply #10 on: March 21, 2019, 12:19:24 am »
At "G" in EL34's grid leak.
Only one is draw. The other channel is identical.
David
Offline chocopower
Re: Musicson 80+80
« Reply #11 on: March 21, 2019, 12:24:45 am »
Is a bit confusing.
I know.
Both channels share the same power supply.
Just the screens have a separate node, the 2 voltage dividers in parallel marked as "B" and "500"
David
Re: Musicson 80+80
« Reply #12 on: March 21, 2019, 08:21:41 am »
Duh. I forgot this is a stereo amp.
Offline chocopower
Re: Musicson 80+80
« Reply #13 on: January 04, 2021, 06:48:18 am »
Time for this one...
Testing transformers.
One of the O.T. is shorted in the primary windings.
I have a O.T. from a another amp that could work.
Is a bit smaller, but according to schematic they worked in a very similar environment.
Both transformers are on the 4.2k  range for primary impedance
What do you think?
(Donnor amp schematic attached)
« Last Edit: January 04, 2021, 08:07:03 am by chocopower »
David
Offline chocopower
Re: Musicson 80+80
« Reply #14 on: January 04, 2021, 08:01:39 am »
The black one will be the replacement.
David
Offline chocopower
Re: Musicson 80+80
« Reply #15 on: January 06, 2021, 10:39:18 am »
Just in case the post get lost, i ask again. Will be a factible replacement?
Sorry for the insistence..... :angel
David
Re: Musicson 80+80
« Reply #16 on: January 06, 2021, 11:22:15 am »
:wink:
Offline chocopower
Re: Musicson 80+80
« Reply #17 on: January 07, 2021, 04:08:08 am »
Ook. What i thought them.
With amps in the 400volt range, i dont use to be so undecided,  but when i see 500+ on the DMM i start to feel dumb as hell......
Thanks!
« Last Edit: January 07, 2021, 05:10:27 am by chocopower »
David
