September 15, 2026, 11:05:10 pm
Hoffman Amps Forum image Author Topic: KT88 PP amp  (Read 54040 times)
Re: KT88 PP amp
« Reply #100 on: April 15, 2019, 06:06:06 pm »
For what it's worth, I really like the Presence on my Major.  Depending on what guitar I use, it allows me to dial in a little bite.  Typically turned off with a strat, it can give a little more top end if loaded down with a pedal(s) on the front end.  With a humbucker it allows for a little or a lot of shimmer over the top - similar to a live Jimmy Page.  As we all know, the Presence is different than just turning up the treble.  It sure makes my amp a lot more flexible.
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Re: KT88 PP amp
« Reply #101 on: April 15, 2019, 06:46:50 pm »
The plan is to have a presence control and the control for the feedback loop as well.
Also there are few more ideas cooking at the moment, I'm reading, researching, gathering info !
Check out also this topic. Body control is another candidate for the amp!
https://soundcloud.com/ukiuki
Offline uki
    • Uki's Guitar Trip
Re: KT88 PP amp
« Reply #102 on: April 22, 2019, 11:26:37 pm »
Some update on this project:
Bias balance, CUT control and
Negative Feedback control, what value for the pot should be used, keep the resistor with smaller value ?
Re: KT88 PP amp
« Reply #103 on: April 23, 2019, 05:16:41 am »
Thanks for sharing the schematic!  I'll be very interested in hearing how you like this amp once built.
Re: KT88 PP amp
« Reply #104 on: April 23, 2019, 02:41:34 pm »
This depends on the speaker and your style. NOT an "electronic" question. Put in two alligator clips and try values from half of stock to infinity.
