September 18, 2026, 11:12:32 pm
Hoffman Amps Forum image Author Topic: Got Iron  (Read 25265 times)
Offline Papa Jim
Re: Got Iron
« Reply #50 on: March 25, 2019, 09:09:06 pm »
Ok. Shooter. Tomorrow I'll do some tweaking. Thanks,
Offline Papa Jim
Re: Got Iron
« Reply #51 on: March 26, 2019, 09:27:47 am »
Bumped the cathode resistor up to 750 ohms to get the cathode current lower.
Plate Voltage = 327 VDC
Cathode Voltage = 21.3 VDC
Plate to Cathode Voltage = 306 VDC
21.3V/750 = .0284A or 28.4mA
327 x .0284 = 9.28W
I haven't removed the choke yet and replaced with the resistor. That will be next.
Since the amp is not over dissipating, guess what? I just had to hear it for a test. Who wouldn't  :laugh:  It is very very hum free, and sounds awesome.
So dissipate a little more and soon as my tubes get here go from try going from (both halves of the 12AX7)  to ( combo of 1/2 of an 12AY7 and 1/2 of a 5751) as a tone experiment. Loving the sound though already. Thanks to all who helped me. I will be sure to keep you all posted on my progress.   :icon_biggrin: :icon_biggrin: :icon_biggrin:
One question are wirewound's suitable for cathode resistors?
« Last Edit: March 26, 2019, 09:32:55 am by Papa Jim »
Re: Got Iron
« Reply #52 on: March 26, 2019, 10:39:58 am »
Absolutely.
Re: Got Iron
« Reply #53 on: March 26, 2019, 10:50:30 am »
you're there without swapping it out, leave it if you like it.  was just a suggestion to lower B+
Offline Papa Jim
Re: Got Iron
« Reply #54 on: March 26, 2019, 10:52:44 am »
Ok. Gotcha. But the 750 ohm was correct wasn't it to get a proper safe dissipation percentage. Before that it was over the max.
« Last Edit: March 26, 2019, 10:54:52 am by Papa Jim »
Re: Got Iron
« Reply #55 on: March 26, 2019, 10:57:52 am »
327 x .0284 = 9.28W
You should use the plate to cathode voltage for your final calculation.
IOW, 306 x .0284 = 8.69W
Offline Papa Jim
Re: Got Iron
« Reply #56 on: March 26, 2019, 11:07:32 am »
Ok. Cool. I will do that after I add the other tube socket and tweak the resistor for a little more dissipation since I am on the low side right now.
Another question is it a good idea to check any voltages on the preamp tubes. The schematic shows 1.5 cathode volts with 150 Plate Volts. Is it the ratio of those two that is important. I suppose it takes tweeking the plate resistor 100k to get this voltage? Is that important.
« Last Edit: March 26, 2019, 11:18:08 am by Papa Jim »
Re: Got Iron
« Reply #57 on: March 26, 2019, 11:17:13 am »
Another question is it a good idea to check any voltages on the preamp tubes. The schematic shows 1.5 cathode volts. Do I play with the plate 100k to get this voltage? Is that important.
Check these 2 videos out. They will give you some of the back story behind the answer to your question:
https://vimeo.com/28565075
https://vimeo.com/33244955
Re: Got Iron
« Reply #58 on: March 26, 2019, 05:41:02 pm »
Your supply rails are zero V and (say) 300V. The tube works with a *part* of the 300V across it and a part across the plate (or cathode) resistor. So as long as the tube plate-cathode voltage is not zero and not full supply voltage, it "is working".
A specific guide: Fender's 12AX7 with Rk=1.5k and Rp=100k, the plate sits near 70% of supply voltage. I would not be distressed about 60% or 80%, except 12AX7 are so consistent around this point that any other result suggests checking resistors and tube. Russian "similar to 12AX7" may be different. 12AU7 *will* bias-up different.
Offline Papa Jim
Re: Got Iron
« Reply #59 on: March 26, 2019, 05:49:54 pm »
Thanks PRR. I just never hear anything on checking them that is why I asked.  :icon_biggrin:
Offline Papa Jim
Re: Got Iron
« Reply #60 on: March 29, 2019, 07:37:21 pm »
Ok so I got the amp done with all three tubes now and I am really loving it. Here's the final schematic. I did change up the tone stack also to the original 5F2A tonestack. The 12AY7 and 5751 worked great together.
« Last Edit: March 29, 2019, 08:05:39 pm by Papa Jim »
